Headlight Modification Help
Old Sep 24, 2013 | 11:57 PM
cmesidewayz's Avatar
Whats up guys, been a while since I've posted. I go to UCF and not much time to work on my car.
I'm looking to change up my headlights, I've searched and found a couple DIY's but getting a little confused. Thought I would just explain what I'm looking for to get a comprehensive answer.
05 Headlights, I already Have clear corners on.
Clear Corners- White w/ amber turn signal
Headlight Strip- White w/ amber turn signal
I would like these to work in unison when the turn signal is on. And also to be the same xenon white as the headlights or as close as possible.
Thanks!
Old Oct 6, 2013 | 02:14 PM
Justdefied's Avatar
You're going to have to splice the wires from the corners and clearance strip (The headlight strip) to the turn signal)... Not too complicated, there are plenty of DIY on how to get access to the lights (Which is probably going to be the "hardest" part) other than that it should be a 10 min job max.
For the color of the lights, it's hard to get ones that perfectly match the OEM low beams but most people have success with the PIAA's T10 wedge bulbs as well as H4 fog/high light. Although people say the PIAA T10 burns out quickly so be prepared to replace them every so often.
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
