Advice needed - filling small gap around splash guard
Old Sep 26, 2013 | 09:59 AM
z-man's Avatar
I recently installed rear splash guards and the passenger side fit perfectly snug, but there is a small gap on the drivers side as you can see in the photo. I want to fill the gap with something and then touch up the paint on the filler.
With the splash guard being plastic (flexing, expanding with temp, etc..), does anyone have any recommendations as to a filler? I'm not sure if I should be using bondo, a paintable exterior caulking, some type of epoxy, etc....
Obviously I've never tried something like this before.....
Thanks
Attached Thumbnails Advice needed - filling small gap around splash guard-photo-5-.jpg
Old Sep 27, 2013 | 04:48 PM
Ejgold55's Avatar
Are they OEM? That side should fit like the other, might want to check with whatever source you bought them from.
Personally i would just leave it be, your the only one that will really notice it. You start using fillers, epoxy, etc....the weather up north, salt on the road, etc, etc.....it will look ghetto fabbed by the end of December and look even worse.
Old Sep 27, 2013 | 07:05 PM
saywat?'s Avatar
put layers of double stick tape till ur satisfied. thats how I gotta make my side skirts fit cus the fitment isn't that good
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
st33zygill
Jul 29, 2015 10:05 PM
itschuckster
Jul 25, 2015 08:07 AM
laksjd84
Jul 24, 2015 05:12 PM
vstypicals
Jul 20, 2015 10:55 PM
