headlight
Old Aug 20, 2015 | 02:41 PM
FRUG35's Avatar
headlight
is there anyway to just replace the outer lens of the headlight because i have one brand new headlight and one yellow one and nothing i do can make it look better. thanks
Old Aug 20, 2015 | 03:03 PM
Jusseth's Avatar
It is more cost-effective to either have the lens polished or sanded and clear-coated instead of exchanging the lens. I believe they do not sell the lens alone.
Old Aug 20, 2015 | 03:12 PM
JG_G35's Avatar
DigitalDeviant bought $200 eBay headlights and swapped the lenses to his 06 projectors. They came out great and would honestly be your only option to get clean lenses. If you have 03-05 headlights then I would just go ahead and swap the entire assemblies to save you the trouble.
Originally Posted by DigitalDeviant
For those of you that don't follow my build thread, I will just leave this here
So my 06 projectors were really cloudy and beyond repair as the damage was inside especially with the stress cracks. So, anyone looking for replacement lenses and can find these cheap like i did. Do it, then just clear coat them.
Before
So, I bought a set of these ebay lights for 200 bucks new.
Then took them apart
Removed the bezel
Here is the gap at the top corner - they sealed just fine and all the screws went in place with no issues.
Installed the 06 bezel and done
Old Aug 20, 2015 | 07:19 PM
Urbanengineer's Avatar
Currently doing the wetland and buff and re clear process. I would consider spending the $200 if I had to do this again. It takes so much time to sand buff and clear. Ty DD.
Old Aug 21, 2015 | 09:07 AM
FRUG35's Avatar
headlight
did you have to bake them to get the lens off how hard was it to do. and i have the 06 headlights so i dont want to replace them
Old Aug 21, 2015 | 09:12 AM
DigitalDeviant's Avatar
Yes, baked @ 200 for 10 mins. It's not hard at all. You just need to remove the ballast and 3 small screws around the edge of the light. Bake, and peel it apart, then swap the inner bezel out. Bake it again and once removed, install the lens and press HARD on the edges to seal it. Bake it one more time to let it seal some more and then take it out, put the scews in and you're done.
Old Aug 21, 2015 | 04:02 PM
What exact headlight did you buy from where? 03-05 replacements? Link please!
Old Aug 21, 2015 | 04:21 PM
These are the ones i bought. Seems they are going up in price.....
http://www.ebay.com/itm/Fits-03-05-G...8b7637&vxp=mtr
Old Aug 21, 2015 | 04:29 PM
These are the ones i bought. Seems they are going up in price..... http://www.ebay.com/itm/Fits-03-05-G...8b7637&vxp=mtr
THX! Did you color mod your projectors while they were open?
Old Aug 24, 2015 | 08:38 AM
No I didnt. I have another set I'm using for retrofit, but it's low on the priority list. This mod was only to clean up these so I can sell them later. They got a few layers of clear over the weekend as well.
Old Aug 24, 2015 | 09:35 AM
gary c's Avatar
Before you drop $200 on aftermarket trash headlights try this...OFF bug spray and a towel which will require rubbing for 10 to 15 minutes. Your headlight will come out clear and it didn't cost you hardly anything!
Gary
Old Aug 24, 2015 | 09:38 AM
Gary
I would agree with trying to clean them up first. However, mine were beyond the sanding / buffing stage as they had tons of stress cracks and yellowing from inside the lens.
Old Aug 25, 2015 | 09:40 PM
saywat?'s Avatar
holy **** u paid the $300 shipping?
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
