Paint code of non metallic Diamond graphite areas? Like engine bay/interior
Old Jul 20, 2016 | 09:59 PM
Spitfire91104's Avatar
I am in the process of cleaning up some small rust spots around the outside and inside of the rear trunk. Main problem area is the trunk lid shock mount which is right in the path of the water drainage ducts so it sees moving water all the time. It isn't crazy bad but I definitely don't want it getting worse.
Is it just a layer of the base coat with a single layer or clear or something? Having my rear bumper cover repainted soon so if it's just base coat I will just have the body shop handle it.
Thanks, Mike
Old Jan 4, 2019 | 10:47 AM
Albanian122's Avatar
Hey I can’t send you a message about the grounding kit your mailbox is full
Jonnyidfw
Lights
14
Dec 11, 2016 12:22 PM
Ultrabootz
Steering & Suspension
May 6, 2016 10:41 AM
GreySky
Apr 24, 2016 02:03 AM
Siciliang35
Apr 23, 2016 04:29 PM
Kicknshift
Mar 6, 2016 03:06 AM
