Catalytic Converter advise please
Need advise G35 members. My check engine light on. Need to get it fix for smog check. It put out code that both catalytic converter need to be replace. Shop say it has to be replace with OEM parts. They quote me $2200. That is part and labor. Any work around? Will after market catalytic converter pass the smog check or do I need to stick with OEM? Thanks in advance.
Any carb compliant bolt on cat for this car should be able to pass emissions just fine. And depending on your states laws, some non carb complient ones will likely work too. Buy a pair for between $200 and $300 each and bolt em on yourself
Check Magnaflow cats, they carry the correct CARB sticker for our state.Gary
