can you replace map light switches?
Old Jun 15, 2019 | 10:46 AM
Tannerwood2k1's Avatar
2004 g35 stock
My driver's map light doesn't work. I suspect a corroded or damaged switch contact. Passenger side works fine, have a known good bulb in the driver's side.
Can I replace the lamp switch in the dome light assembly? Or do I have to buy a whole dome light assembly and swap that out?
If I can replace the switch, does anyone know what a part number for it would be or where I could buy one?
Old Jun 15, 2019 | 12:27 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Probably just a dirty contact. Take it out and inspect then clean with electrical contact cleaner.
Tannerwood2k1
Jun 15, 2019 12:33 PM
