How to change the fog light bulbs
Old Mar 18, 2005 | 09:32 PM
Rookie84's Avatar
Ok. I searched all over the forums and web for DIY instruction and couldn't find any. The ones I found are very old and all the links are broken. If anyone has detailed instructions with pics, please help me. I just can't figure out how to get the damn plastic cover off... I'm trying to do this without removing wheels. Thanks in advance.
Old Mar 18, 2005 | 10:03 PM
Sponger's Avatar
6MT Brembo Coupe
Turn wheels all the way to left or right depending on the side you're working on. Lift the car up a few inches using a floor jack and remove some of the clips holding the inner fender liner. Pull the liner down a little and you will have access to the clip and plug to the fogs.
Old Mar 18, 2005 | 10:12 PM
WRAH's Avatar
WRAH
becareful w/ the jack, it can be done w/o lifting the car!
Old Mar 18, 2005 | 11:03 PM
Rookie84's Avatar
I was trying to do that but couldn't figure it out... Do I remove clips and pull down from the bottom front or in the top part?
Old Mar 19, 2005 | 01:37 AM
gdragon's Avatar
thinking about removing the bumper and headlights for access? pm me for pics and instruction if interested.
Old Mar 19, 2005 | 01:48 AM
Sponger's Avatar
6MT Brembo Coupe
A little of both, and removing the clips. If I remember correctly, you will notice the front and rear liners are hinged together. Once they're unhinged, pull down on the front liner to gain access to the bulbs.
Old Mar 19, 2005 | 02:19 AM
RacerB355's Avatar
i found it easiest to take of the wheels, pull back the fender by removing all tabs and bolts, and then you have direct access to the back of the headlight, worked out great
Old Mar 19, 2005 | 06:24 PM
Rookie84's Avatar
I tried for second time today and finally succeeded after an hour of trying Once I figured it out, it only took me 10-15min to do the other side I was cussing out Nissan engineers for making it such a PITA to change freaking bulbs the whole time... haha. I jacked up the car a little with the wheels turned to one side and that gave me enough room to work on everything. I put in PIAA Xtreme whites in clearance strips and clear corners, and put in MTEC 4350k H4 bulbs in fog/high. I love the look... everything is clean white Thanks everyone for help and suggestions.
Old Mar 22, 2005 | 07:43 PM
transportchef's Avatar
Where did you get the mtec's from? I tried istoreparts.com(backordered).
Old Mar 23, 2005 | 10:41 AM
6-Sigma G35's Avatar
Thumbs up EBay
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
This is the EBay auction I won for my MTEC's. I had my bulbs 3 days later. they were packaged well (i.e., protected from damage).
Give this guy a try.
Larry
Old Mar 23, 2005 | 11:29 AM
Thanks bud.
Old Mar 23, 2005 | 06:57 PM
Rookie84's Avatar
Yeah. I bought MTEC's from the same guy They really match the stock HID's well! I love it
Jusseth
Sep 13, 2020 12:25 PM
Freddy07g35
Sep 17, 2015 08:53 PM
Fireman07603
Aug 9, 2015 06:00 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
attarday
Jul 15, 2015 04:03 PM
