Step light bulb = center dorm light bulb?
Old May 23, 2005 | 12:34 AM
kenempireex's Avatar
are they the same? I bought a pair of blue dorm light, realized that they are too dark and want to put them for step light. However, their size are a little different.
Old May 23, 2005 | 02:04 AM
escobar929's Avatar
are you talking bout the dome lights (map lights)??? if you are then yes they are the same. They're both T-6.
Old May 23, 2005 | 03:04 AM
the size ain't the same
Old May 23, 2005 | 04:32 AM
skeleton_cru's Avatar
Sedan
The T6 bulb is bigger then the stock step light bulb but it will work. I have PIAA T6 bulbs in my doors.
Old May 23, 2005 | 05:08 AM
Silverbolt's Avatar
This is what Osram Sylvania has listed....
Map light
DE3175
Dome light
DE3175
Step/Courtesy light
DE3022
Trunk/Cargo area
158
Old May 23, 2005 | 05:31 AM
so i can jam the dorm bulb into the step light. Will it burn the wire?
Old May 23, 2005 | 06:15 AM
Sedan
Yes, it will fit with a little extra pushing. It will not "burn the wire".
Old May 23, 2005 | 01:33 PM
ok, thanks for all the replies
Old May 23, 2005 | 07:03 PM
uh...can anyone else confirm that the bigger blub won't burn the wire? I jam them in, and they are really bright
Old May 23, 2005 | 07:09 PM
escobar929's Avatar
your safe, i've had them for over two months and they still look great
Old May 23, 2005 | 07:53 PM
Sedan
I've had them in for probably six months, no problems whatsoever.
Old May 23, 2005 | 11:57 PM
krod69's Avatar
Can someone explain how to change dome and step lights? Thanks
Old May 24, 2005 | 04:35 AM
It's in the manual with pictures.
Old May 24, 2005 | 11:30 AM
Pratik's Avatar
Moderator
I just swapped both of them out with T-6 bulbs. It literally took me all of 5 minutes to do all 4 bulbs. If you're in the DC area let me know and I can help you out or you can come out to the National G Club DIY day on June 4 and I can swap them for you then.
Old Apr 4, 2006 | 12:39 AM
I Scare's Avatar
where can i get the blue step light bulbs? i couldn't find it at the stores.
