changing the fog lights
Old Jun 15, 2005 | 08:41 PM
g35kid18's Avatar
I need to know how to change the fog lights i cant figure out how to pull of the light fixture. help please
Old Jun 15, 2005 | 09:16 PM
Silverbolt's Avatar
Do a search in the DIY sub-forum
Old Jun 15, 2005 | 11:28 PM
Asianicboi's Avatar
the search button is your best friend =]
Old Jun 15, 2005 | 11:51 PM
escobar929's Avatar
1) Jack the front of the car up a little so you can reach into the wheel well area easier..
2) turn front wheel in on side your working on.....
3) remove the five (5) black plastic fastners ( you lift the center portion with a small flat screw driver, then remove the entire fastner)
4) there are two (2) phillips head screws on the top of the wheel well fender lip....remove them as well...
5) You should now be able to pull down the wheel well liner from the top center....this will give you access to the back of the headlight assembly.
6) Locate the fog light cap (red and yellow line) and twist the cap counter clockwise.
7) Locate retainer ring and use your thumb and index finger to squeeze in until the retainer ring is loose and drops down. (The bulb is loose at this point.)
8) Use a clean/dry towel and carefully pull the bulb out from the fixture.
9) Use a clean/dry towel and carefully insert the new bulb into the fixture.
10) Carefully insert the bulb into the housing.
11) Pull the retainer ring up and squeeze it back in against the back of the fixture.
12) Test to see if the fog light turns on.
13) Seal the cap clockwise
14) Push the wheel fender back in and tighten the screw and tabs and you are done.
Old Jun 16, 2005 | 06:48 PM
QuadCam's Avatar
I only needed to remove (1) 10mm bolt from the bottom of the fender liner and (1) philips head screw high up on the liner. At that point, I could peel back the liner and get access to the back of the headlight.
It is a tight squeeze. I had fairly large hands, but I was able to do both lights in about 25 minutes total. the 1st 15 minutes for the drivers side because I wasn't sure how everything fit together.
Old Jun 16, 2005 | 06:51 PM
S-Tuned's Avatar
gtr proto test driver
to get access to it its the same as changing clearance bulb...
Old Jun 17, 2005 | 09:00 PM
g35kid18's Avatar
thanks guys
Jusseth
Sep 13, 2020 12:25 PM
Freddy07g35
Sep 17, 2015 08:53 PM
Fireman07603
Aug 9, 2015 06:00 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
attarday
Jul 15, 2015 04:03 PM
