ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh help
Old Sep 28, 2005 | 08:27 PM
ebuy929's Avatar
hey guy,
i managed some stupid stuff again .
i was changing the leds bulbs in my headlight pipe light and the bulb kept failng out so i took tweaser and tride to tighten the gold clams holdin the bulb to make it stay. next thing i know my stipe light are not working, my corner light are out, my tailights only turn on when i brake, my licence plate wont iluminate, my headlight turning signals only work when i signal not when xenons and fogs are on, and finally my center consol has no lights..
by the way i have a coupe and the light i original tried to install where the little side stripe lights on the side of the headlights. i gues i crossed positive and negative and blew a fuse
i took it to a shop and they couldnt find the correct fuse box to check the fuses they found the one by the battery and under the drivers side . they couldnt find any other fuse boxes for the accesory lights (there was nothing under passenger side)
basicly where is the correct fuse box located.
also what do u think the problem is . a fusE? the mechaninc said its possible i messed up the relay system flasher or somthing and im fuked. ithnk its a fuse
any ideas help suggestion>?
please
Old Sep 28, 2005 | 08:43 PM
S-Tuned's Avatar
gtr proto test driver
get that **** to infinti.. dont mess with it
I read this whole thing and I still dont understand how the hell you managed to do so much damage with a LED light
Old Sep 28, 2005 | 08:46 PM
G352NV's Avatar
Never enough
The fuse that it would be is next to the battery under that plastic cover. If its not that then I dunno what it would be.
I would try unhooking the bulb you were messing with.
Old Sep 28, 2005 | 11:59 PM
shipsaeki's Avatar
its called the IPDMR, Remove your batter cover and also the cover that your batter cover sits on. Basically, you will see a little black cover right next to the battery...
no no the box with fuse's and relay's. this one sits to the left of the battery, not in front. in that box there are fuses for fog lights, headlights and some other stuff. But I would take it to a dealer and have them check it out.
