Headlight not working
Old Oct 4, 2005 | 11:25 PM
G's Up's Avatar
My passenger side headlight was not working, the fogs and the clearance strip were working fine, and magically the next day it started working again
My car did this a month ago and now its doing it again...not sure what it could be...
has anyone had this problem or can anyone provide an explanation?
Old Oct 15, 2005 | 01:29 PM
G's Up's Avatar
bump
Old Oct 15, 2005 | 01:38 PM
PeteNJ's Avatar
Check to see if the harness connection has come loose.
Old Oct 15, 2005 | 07:43 PM
cutiewolf's Avatar
ur turning ON ur headlights too quick...go ez on them...2nd check if theres crack on headlight housing if any leaks into it this a big problem ..
Old Oct 26, 2005 | 06:05 PM
G's Up's Avatar
update!
The dealer replaced the bulb and the ballast today! they were not sure what was causing the problem so they replaced both.....works fine now...there did not appear to be any moisture or problem with the seal as far as i could tell.
as far as turning on the headlights slow, i dont know what you mean by that, i just turn the switch like everyone else...
Thanks for the input guys!!!
Old Oct 27, 2005 | 03:28 AM
RashMan1450's Avatar
yea i know wat the problem was, because i had the same problem and i fixed it. The balast was not properly tightened. It came loose for some reason
glad to see you fixed it
Old Oct 27, 2005 | 01:27 PM
LjN_728's Avatar
Glad to hear you got them fix and was coverage by the dealer.
Yea I don't agree with you on that one. There's no incorrect way to turn your headlights on.
Old Oct 27, 2005 | 02:24 PM
1001's Avatar
mine does the same thing but on the driver side. i don't know if it is because i changed my HID bulb or what?
bTanz
Oct 15, 2015 02:31 PM
EPG35
Aug 16, 2015 04:52 PM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
attarday
Jul 15, 2015 04:03 PM
