having trouble retightening fog light cover
Old Oct 8, 2005 | 06:13 PM
rcdash's Avatar
Did anyone else have trouble putting the round black cover back on after replacing the fog light? It worked no problem on the passenger side. The driver side - it goes on and twists tight for about 1 cm, then slips. It was nice and snug when it came off.
It's so hard to see what might be the problem???
I have left it in a tight position, but if you twist it half a cm left or right, it's going to be loose. Worried that with vibration, it might come loose.
Any suggestions? I played with it for an hour cursing the whole time! (The other side took 10 mins start to finish to change the fog)
Old Oct 8, 2005 | 06:26 PM
PeteNJ's Avatar
Take out the headlight and see what is going on. You don't want that cover to come off or be loose as condensation will enter the housing.
PS: You need to remove the bumper to get to the headlight (Don't do it the ghetto way of taking only the top clips off)
Muski_G
Dec 1, 2023 11:11 AM
Jusseth
Sep 13, 2020 12:25 PM
Freddy07g35
Sep 17, 2015 08:53 PM
newg37
Jul 26, 2015 09:32 AM
attarday
Jul 15, 2015 04:03 PM
