Debadging hurts- literally, help
Old Oct 13, 2005 | 09:01 PM
cloud's Avatar
Okay now, I got the G35 only off in like 45 minutes. I spent most of the time rubbing REAL HARD trying to get the left over double sided tape off the car. and, while I was doing it i didn't notice my nail actually sorta partially tore off my flesh.
Is there an easier way to do this? I'm not using goo gone cause I can't seem to find it. I got an adhesive remover(duck brand) from target that doesn't seem to be doing anything.
Old Oct 13, 2005 | 09:15 PM
GsUpHoesDown's Avatar
heat it up with a blow dryer.
Old Oct 13, 2005 | 09:21 PM
mc2's Avatar
mc2
googone can be found in walmart!
Old Oct 13, 2005 | 09:24 PM
GodZilla's Avatar
Originally Posted by cloud
Okay now, I got the G35 only off in like 45 minutes. I spent most of the time rubbing REAL HARD trying to get the left over double sided tape off the car. and, while I was doing it i didn't notice my nail actually sorta partially tore my flesh.
yeah what he said above
Old Oct 13, 2005 | 09:42 PM
dannyboi2088's Avatar
noo noo nooo use seomthing like a credit card something thick and dont rub it too hard to else you'll get scratches on your car.........use the credit card and spray WD-40 on it........it really works well and it wont ruin your car
just keep spraying WD-40 a lot and then rubb and then wipe off wit a cloth and keep repeating it
Old Oct 13, 2005 | 10:24 PM
cloud's Avatar
you mean using the card instead of the floss right?
or scraping the double tape residue off with a credit card?
Old Oct 14, 2005 | 11:15 AM
GT-Ron's Avatar
Goo Gone. And as for items to help you rub the adhesive off...
... don't use anything that you wouldn't polish your car with. If you've got some good towels that you use for Zaino (or other polish), use that instead of your fingers. Just make sure it's a GOOD towel or else you'll scratch it and have to buff it out.
Old Oct 15, 2005 | 07:55 PM
cutiewolf's Avatar
i used hot water
Old Oct 17, 2005 | 01:38 AM
dcam's Avatar
Use heat to warm up the tape and then it comes off easier. Never tried hot water, but should do the trick.
Old Oct 17, 2005 | 02:09 AM
BlazeMaster's Avatar
so the goo gone and the wd40 won't hurt the car paint?
Old Oct 17, 2005 | 04:31 AM
skeleton_cru's Avatar
Sedan
No, as long as you wash it off immediately after the job is done.
Old Oct 17, 2005 | 06:59 AM
Og_Dave's Avatar
i use gum and tar remover, takes it off without any scratches, then i use abit of wax and its good to go
hah but i done it at the nissan dealership, cuz i used to work at the detailing part and some of the good detailers told me how to do it
Old Oct 17, 2005 | 08:38 AM
G35_TX's Avatar
Googone and wd-40 will not damage the car. You are safe with using those on hthe paint. But once you remove the emblems you might have some different color areas where the emblems were. You you might need a buff.
Old Oct 17, 2005 | 09:36 AM
JDM 350GT's Avatar
wd-40...easiest way.
not familiar w/ goo gone.
one can of wd-40, worth every penny
Old Oct 17, 2005 | 06:46 PM
TOPSECRET2001's Avatar
rubbing alcohol works great as well if you can't find any f the other products listed above...
