Just got my Phillips 6000k But~!! (help)
Old Oct 26, 2005 | 11:25 PM
nosey's Avatar
i just got my phillips 6000k bulbs But i noticed that on one of the bulbs, the ceramic tube covering the wire parallel to the bulb is cracked on the end that gets plugged in. Its slides back and forth if i tilt the bulb. is that something i can fix ?? or can i just use it the way it is ?? or do i have to return it??
my main concern is if that piece moves the way i just described, will it shorten the life of the bulb??
any help would be nice
thanks
pic attached w/ broke area circled in red
Old Oct 27, 2005 | 12:27 AM
WRAH's Avatar
WRAH
If you can't take them back (which) you should, then you can use a high temp cerm. glue.
That piece does two things, Prevents shorting, and prevents the wire getting too hot.
Old Oct 27, 2005 | 02:35 AM
ColdFusion's Avatar
Maybe two years ago, i cracked that ceramic piece in my 6k bulb when i was removing it from my TL and putting it in my G. The bulb is exactly how you describe yours and it still works fine. No problems so far. If you can still get it replaced, then do so, but if you cant, i dont think it matters
Old Oct 27, 2005 | 08:20 AM
nosey's Avatar
thanks for you help..i really appreciate it
Old Nov 15, 2005 | 02:55 AM
siiiing's Avatar
Mad eyed G
There is a one year warranty on all Philips Ultinons... get it replaced if from a vendor if you purchased them from one.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
lil beezy
Lights
Nov 16, 2015 02:52 AM
twentyeggs
Sep 11, 2015 03:58 PM
JoeP
Aug 1, 2005 01:49 PM
godlike0104
Oct 16, 2004 05:38 PM
