kuruma grill here
I used really short screws w/ washers to put mine in... you have to be VERY careful when you screw them in... do it at the furthest point away from the finished edges as you can as you can poke thru very easily...
i figure out what i am goin to do. i am goin to use lock tie with the screws so that way it will b more secure. i suggest every1 do that b/c the screws r so small and jus in cas a rock or something should hit the grill it wont knock it off.
