i don't think that is possible to fix. it might be but it will cost some serious coin, your better off just buying a new what ever it is. also it shouldn't spread doesn't look like there is a crack going though the carbon fiber
never heard you can fix carbonfiber. you can only fix the clearcoat, but since this is a chip off the carbonfiber doesn't look fixable. if there is a way, i would think it wouldn't be worth it.
Never enough
You cant fix it without painting it. Its like fiberglass so yes it can be fixed but you'll be able to see the fix. You can glass it on the back so it doesnt go any further but if you fug with the front side it will need to be painted.
I wonder if i can just clean up the front and reclear it (like wet sand it some)? Wouldnt that work?
Its under the car so how it looks doesnt matter alot, but i dont want it to be ghetto.
