Help - removing airbag on a 2005 coupe
Old Jul 21, 2006 | 10:52 PM
zackt69's Avatar
rarejdm.com
So I got the Nissan airbag cover from a friend in Japan, and I'm trying to take off the airbag so I can replace the cover. Problem is the bolts holding the airbag in place are strange, almost like little wheel locks... anyone know how to get these off? I did a search and the only thing I found said to use a t30 torx bit, but that doesn't fit. Oh, and both bolts are totally different -
Thanks!
Zack
Attached Thumbnails Help - removing airbag on a 2005 coupe-steering_001k.jpg   Help - removing airbag on a 2005 coupe-steering_002k.jpg
Old Jul 22, 2006 | 12:55 AM
meatbag's Avatar
looks like a torx bit
Old Jul 22, 2006 | 05:58 PM
G352NV's Avatar
Never enough
Go to kragen auto or a auto parts store. They have a set you can buy for about 10.00. Its a security torx.
Old Jul 22, 2006 | 06:17 PM
elrooko's Avatar
I bought a set of them at a local auto supply store. The guy knew what they were and said that they were pretty common. The 5 heads cost me $30 CDN. Also some store rent out tools, you might want to try that as well.
Old Jul 22, 2006 | 11:04 PM
_G_'s Avatar
_G_
I bought my TORX bit from autozone. There's different sizes, so I would suggest trying them out before you leave the parking lot of the store. This way you can return them right away if you got the wrong size.
Here's some pictures I took when I swapped mine out.
Good luck.
Attached Thumbnails Help - removing airbag on a 2005 coupe-slide2.jpg   Help - removing airbag on a 2005 coupe-slide3.jpg   Help - removing airbag on a 2005 coupe-slide5.jpg   Help - removing airbag on a 2005 coupe-airbag-removal.jpg   Help - removing airbag on a 2005 coupe-slide7.jpg
Old Jul 23, 2006 | 09:23 PM
zackt69's Avatar
rarejdm.com
Thanks guys, I got it off. The pics were a lot of help -
Zack
Old Aug 10, 2006 | 11:56 PM
Genius668's Avatar
Anyone know where to buy NISSAN airbag cover online?
Old Aug 17, 2006 | 04:37 AM
accordfreak's Avatar
thanks for the thread bump . I needed this thread
Luisgalvan33
Jul 19, 2018 08:16 PM
mike730
Jan 12, 2018 04:25 PM
trulegend
Audio/Video/Electronics
Jul 31, 2015 03:37 PM
lemmy999
Jul 25, 2015 12:13 PM
