How to remove the door panel
Old Jan 10, 2008 | 06:02 PM
MIA BlazinVQ's Avatar
brb getting cut
Question How to remove the door panel
I've been searching for a while now but only found instructions on how to take off the door panel off of a sedan, but it doesn't
seem to be the same as the coupe. Does anyone have detailed instructions to take off the door panel in a coupe (with newer interior if it matters)?
The reason is because I want to reset the window motor. Thanks in advance.
Old Jan 10, 2008 | 06:14 PM
donnie106's Avatar
You dont have to take off the door panel for that. Just roll your windows down and hold the button for 10 seconds and it will reset, Do the same when you roll them up
Old Jan 10, 2008 | 06:19 PM
brb getting cut
HUH? you mean the button used to roll the window down? who told you that? i'll go try it anyway just for the hell of it.
Old Jan 10, 2008 | 06:24 PM
brb getting cut
Now THAT didnt work.
Old Jan 10, 2008 | 06:32 PM
donnie106's Avatar
yes it works when you roll down the window keep on the switch until you hear a click and when i clicks it will stop working for like 30 seconds and that means its reset
Old Jan 10, 2008 | 06:36 PM
Nismo G's Avatar
That is probably the sound of your motor circuit popping hahaha i have never heard of this, but w/e
-Sean
Old Jan 10, 2008 | 06:38 PM
brb getting cut
hmm it did make that clicking sound and it did stop working for a couple of seconds but I let it roll back up using the auto-mode
and it still went back down a quarter of the way on its own.
Old Jan 10, 2008 | 08:15 PM
Jason@Riverside's Avatar
if you have a Fax machine I can send you the info...
Old Jan 10, 2008 | 08:37 PM
Scrooge's Avatar
I got this from alldata
DOOR FINISHER
Removal
1. Remove mask of inside handle portion and remove screws.
2. Insert taping flat-bladed screw driver into edge portion disconnect pawls and remove grip finisher.
3. Remove screw of grip portion.
4. Insert driver rolled with cloth between panel on vehicle and clips (as indicated with arrow) and remove finisher.
5. Pull up door finisher and remove power window switch and electrical parts connectors.
6. Remove lock **** cable and inside handle cable of inside handle assembly back side.
7. Remove inside handle screws and remove it from finisher. Lock **** cable
8. Disconnect metal clips and pawls from door finisher back side and remove power window switch finisher.
Installation
Install in the reverse order of removal.
CAUTION: To install finisher, check if all clips are matched over holes of panel on vehicle, then push it.
Old Jan 10, 2008 | 08:45 PM
brb getting cut
i'll PM you the fax number for my brother's house tomorrow cuz I dont have one. thanks man
Old Jan 10, 2008 | 08:47 PM
brb getting cut
thanks Scrooge. do those instructions take me to the window motor though?
Old Jan 12, 2008 | 12:02 AM
Scrooge's Avatar
Removal and Installation
FRONT DOOR GLASS AND REGULATOR
REMOVAL
1. Remove the front door finisher. Refer to "DOOR PANEL".
2. Operate the power window main switch to raise/lower the door window until the glass mounting bolts can be seen.
3. Remove the glass mounting bolts.
4. While holding the door window raise it at the rear end to pull the glass out of the sash toward the outside of the door.
5. Remove the mounting bolts and remove the module assembly.
6. Disconnect the harness connector for the module assembly and uncap the harness from the back.
INSTALLATION
INSPECTION AFTER REMOVAL
Check the regulator assembly for the following items. If a malfunction is detected replace or grease it.
* Wire wear
* Regulator deformation
* Grease condition for each sliding part
The arrows in the figure show the application points of the body grease.
Old Jan 19, 2008 | 05:27 AM
hipvspec's Avatar
i found this very useful
Old Jan 20, 2008 | 03:00 AM
Sponger's Avatar
6MT Brembo Coupe
If you're looking to reset, the button is located in the middle of the door after you remove the door panel. Remove the round black sticker and you'll find it.
To reset, start with the window rolled up. Roll window all the way down (not auto mode) while holding reset button. Let go of the button and roll window back up (again, not auto mode).
Danielek
May 1, 2022 01:28 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
douglas555
Sep 10, 2015 04:48 PM
jbmw002
Sep 3, 2015 08:42 PM
