How can I have a hand brake
Old Feb 19, 2008 | 01:47 PM
partyman66's Avatar
Originally Posted by roddymerritt
FUN, my IS was an auto and I still was able to drift it I'm hoping for the same in this car
I don't think a handbrake on a G35 will lock the wheels up if you're moving and you yank it.... at least not the stock one on our cars.
Old Feb 21, 2008 | 04:28 PM
roddymerritt's Avatar
really have you or anyone ever tried
Old Feb 21, 2008 | 04:35 PM
w33ps's Avatar
I still don't understand why its necessary to have a handbrake on an automatic....
Parking on slopes/hills.
Old Feb 21, 2008 | 05:35 PM
I think I'm just gonna try and get a 6 speed now
Old Feb 26, 2008 | 06:29 AM
junoseki's Avatar
just sell and get a 6mt. really, i have no idea why someone would buy such a car in auto. next time if you want an auto, be true to yourself and get the sedan. infiniti realized this, so should you. or maybe you could get really crazy and start the foot pedal drifting style.
Old Feb 26, 2008 | 06:31 AM
junoseki's Avatar
yes, the handbrake does work on a drift on the g35. that's why it's there on the 6mt. try it, it's fun (do it in a safe place).
Old Feb 26, 2008 | 05:54 PM
SlooberTooth's Avatar
Is it possible to just slap on the 6mt center console onto a 5at? Or do you have to retrofit it and custom mod it to fit?
Old Feb 26, 2008 | 06:04 PM
redlude97's Avatar
Thats what the footbrake is for
Old Feb 26, 2008 | 06:16 PM
OH6 G35's Avatar
We need someone to try this!!
Old Feb 26, 2008 | 08:57 PM
Beebo's Avatar
mine does...
Old Feb 27, 2008 | 03:22 AM
ILLicit's Avatar
This is a simple mod, your e-brake pedal cable runs right underneath your car, so all you gotta do is get a 6mt center console and weld a mount to the chassis for the hand brake and run the cable underneath the car. A shop wouldnt charge more than $100 to fabricate a mount if you already gutted your interior (which is easy).
Old Feb 27, 2008 | 02:12 PM
Thinking
Old Feb 27, 2008 | 02:17 PM
mal_TX's Avatar
You can drift a RWD car without using a handbrake....
In fact, I've never used it for that purpose. When I had a FWD car I certainly did handbrake drifts. But in my 6mt, the handbrake is just for holding the car on a hill.
If I want to rear to come around I just mash the gas pedal while turning. Not hard at all and I've actually had a few scares that required full steering lock to catch the slide... I can't imagine why I would need a handbrake for this.
EDIT: Oh and actually... wouldn't you stall your engine if you did not mash the clutch pedal before pulling your handbrake? I mean, if you lock-up the rear wheels to "drift" (that's not drifting) then you better not have the engine connected to those same wheels at the time. Anyway.. you're talking about a handbrake turn, which is not the same as drifting. Usually drifting is done w/ the car under power.
Old Feb 27, 2008 | 02:20 PM
redlude97's Avatar
This requires either excessive power or approaching a turn with too much speed,not always practical in all drifting situations. one of the ways of drifting used by even the pro's is to pull the handbrake with the clutch in to break the tires loose, and then dumping the clutch to continue the wheel spin
Old Feb 27, 2008 | 02:31 PM
  #30
mal_TX's Avatar
I can see how that might make sense in some situations but it wont apply to an automatic.
