How can I have a hand brake
Old Feb 27, 2008 | 02:32 PM
  #31
redlude97's Avatar
Originally Posted by mal_TX
I can see how that might make sense in some situations but it wont apply to an automatic.
Which is why I keep asking them why they need a handbrake
Old Feb 27, 2008 | 02:35 PM
  #32
ON's Avatar
ON
Thats what the footbrake is for
It is easier to shift out of "park" on a slope if you use the parking brake.
If you park on a slope, put it in "park", and let go of the brakes, the car will slide back a bit and somewhat "lock". And when you shift out of "Park", it'll be slighty harder to shift out of park. Other than that reason, i have no idea what you would need if for.
Old Feb 27, 2008 | 02:36 PM
  #33
mal_TX's Avatar
I think they do not know how to perform a power-slide/power-on drift and thus they want to drift it like it's a FWD civic dragging the rear from side to side while the front wheels smoke...
Old Feb 27, 2008 | 02:52 PM
  #34
redlude97's Avatar
So why wouldn't you engage the footbrake before letting go of the brakes? Wouldn't that accomplish the same thing as a handbrake?
Old Feb 27, 2008 | 02:54 PM
  #35
redlude97's Avatar
technically, it kind of works with an automatic also, if the TC unlocks and you pull the handbrake, you can get the wheels to break loose and then mash the gas, similar to a clutch drop in a 6mt, but not nearly as effective and not great on the transmission/engine
Old Feb 27, 2008 | 03:43 PM
  #36
ON's Avatar
ON
oh...i wasn't thinking...when you said footbrake, i thought you meant the regular brake pedal. my bad.
iunno then...convenience???
Old Mar 2, 2008 | 09:10 PM
  #37
Bimmer G's Avatar
I have an automatic and i can drift it just fine. There's different ways of breaking the rear loose. If you wipe it the opposite way of the up coming turn and the n throw it into an oversteer and that puts it into a drift as long as the drive control it.
Old Mar 2, 2008 | 09:12 PM
  #38
Bimmer G's Avatar
Smoking!!!!!!!!!!!!!
Attached Thumbnails How can I have a hand brake-g35-burnout-college-park.jpg
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
alessandro
Oct 8, 2015 09:29 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
