Removing the seats (HELP) !
Old Sep 30, 2008 | 12:22 PM
DDD*G35's Avatar
Can someone tell me how to remove the seats I thought It would be simple but when I was unscrewing the bolts I was having issues with the power part that moves the seats back and forth couldnt remove the seats .
I have an 04 G35 Coupe Thanks .
Old Sep 30, 2008 | 12:30 PM
balla's Avatar
there are only 4 bolts holding the seat down, once those are unbolted you need to unplug i think 3-4 plugs under the seat. DISCONECT THE BATTERY FIRST!!!!!!!!! let it sit for like 10 min. the yellow plug is the airbag plug so disconnect the battery before unpluging. the part that moves the seat is connected to the seat when you remove it, everything is connect to the seat. Hope that helps. Ive removed mine over 5 times now haha it gets faster and faster each time.
Old Sep 30, 2008 | 07:05 PM
DDD*G35's Avatar
Seats
Ok, So I dont remove the bracket thats mounted onto the floor of the car. The 4 bolts must be between the bracket and the seat right ?
Old Sep 30, 2008 | 07:10 PM
ttrank's Avatar
Grocery getter
There are 4 bolts that mount the 4 corners of the seat rails to the car. It's not hard, they are in each corner on the floor.
The seat and motors are all attached.
Old Sep 30, 2008 | 09:28 PM
DDD*G35's Avatar
Thanks guys I figured it out. I didnt realize their was a cover on the mounts in the back.
Old Jul 6, 2009 | 11:05 AM
idrive_MD's Avatar
sorry to bump an old thread but this one seemed to touch base on a problem I have encountered...I removed my seats this weekend to do a thorough cleaning. I didnt bother/think to unplug the battery before removing the seats...I plugged everything back together and now my airbag light wont go away.
Is there a reset for this? or will it eventually go bye bye?
Old Jul 7, 2009 | 01:14 AM
DDD*G35's Avatar
Same thing happen to me and you need to get it reset. Go to your local Automotive Service shop.
Old Jul 7, 2009 | 06:54 AM
Dranom's Avatar
just unplug the battery and see if it resets. leave the battery unplug for like 30mins or so
Old Jul 8, 2009 | 01:39 PM
idrive_MD's Avatar
if all it needs is an ecu reset i'll plug in my BlaztII controler, it has a simple ecu reset. i guess if that doesnt work i'll leave the battery unplug for a little bit...thanks!
Old Jul 8, 2009 | 01:44 PM
Frankieg35's Avatar
How do the covers come off?? I don't want to snap them..
doakley92
Sep 25, 2015 12:58 PM
TNRocker
Sep 21, 2015 08:36 AM
zcherub
Sep 10, 2015 12:03 PM
pasjr1972
Sep 1, 2015 10:17 PM
