Notices
does the razo shiftknob AT rotate?
Old 11-08-2008, 12:03 PM
SxExCx's Avatar
it is fine...it turns by design
Old 11-08-2008, 02:21 PM
G35Papa's Avatar
Originally Posted by dev1983
it looks good on 05+, i dunno how it will look on 03 tho bc of the round base. anybody got pics of that?
Old 11-08-2008, 02:31 PM
5150DS's Avatar
So, does the **** just sit there, not really secured? And you push the whole **** down, not a button like stock? Does it rattle?
Old 11-09-2008, 02:51 AM
G35Papa's Avatar
There is a collar thta is secured with two set screws that go onto the OEM shifter shaft. From there, the base of the **** screws into the main section of the ****...the collar is inbetween those two pieces.
Yes, you push the whole **** down, no button. No it doesn't rattle. There is a large spring inside the **** itself that pushes up to keep tension on the **** which prevents it from moving up/down and rattling.
Old 11-09-2008, 10:08 AM
snotf's Avatar
+1, looks really dees there. i might get it even though i have the triptronic.. not sure how it'd look but i figure there's enough interest i could resell it fairly easily.
Old 11-10-2008, 11:32 AM
Mr.PotatoHead's Avatar
what do you mean even if you have the triptronic?
Old 11-16-2008, 12:45 AM
silvG35's Avatar
hey can u swap out the **** on the auto 03 G35 also or just on the 06 and ^
Old 12-11-2008, 10:17 PM
mastaxkevin's Avatar
with this **** can you open the double din screen without putting in neutral? im interested in one (06 coupe)
Old 12-11-2008, 10:23 PM
Kazaam's Avatar
Old 12-11-2008, 11:23 PM
fluffy's Avatar
wish someone would make a shorter and smaller shift ****....
Old 12-30-2008, 10:37 PM
G35pwrd's Avatar
Where did you get the **** from??? I have called everywhere and checked a bunch of web sites, but got denied when they figured they were out of stock. Do you know if they had it in black????
Old 01-08-2009, 01:40 AM
millsG's Avatar
im trying to do the same, a double din screen that pops out might hit the razo shift ****, it would be my luck that it would break like this. does anyone know of this happening? mines a 06 sedan
Old 01-28-2010, 07:32 AM
White G35's Avatar
Originally Posted by SxExCx
How did you attach the boot to the Razo AT shift ****? Thx I have an '06 auto and would like to know how to attach the boot to the ****. The boot has a metal square piece, do you remove it?
Old 01-30-2010, 10:32 PM
aBLUEg35's Avatar
i like it but it might be too tall.. the 6mt guys get all the options.. can a mt **** be modified?? has anyone done it?
  #30
Old 01-30-2010, 10:40 PM
kennymo's Avatar
the razo **** sits way lower than the stock ****.
a double din screen will move freely with this **** also.
heres a pic of it in my o4
Quick Reply: does the razo shiftknob AT rotate?
