how to remove coupe rear middle section?
Old Oct 4, 2009 | 03:37 PM
ac419's Avatar
hi.. i was wondering if anyone knows how to remove the rear middle section (plastic) piece of the coupe. thanks.
Old Oct 4, 2009 | 09:18 PM
DrewTheSuit's Avatar
if you are referring to the rear cupholder section that seperates the rear seats then you need to remove the whole lower rear seat section
Old Oct 4, 2009 | 11:53 PM
ac419's Avatar
how do you remove that?
Old Oct 6, 2009 | 03:45 PM
roll your seats forward, stradle the hump in the floorboard in the center of the back, grab the lower portion of the seats cushions and pull up...it's held in by two big metal clips if i remember correctly....ps don't forget to feed the seats belts/buckles through the lower portion before you remove the lower cushions...once it is out, turn it upside down and you will see a thin metal rod that the cupholders are clipped onto....took me about 10 mins the first time i tried HTH
Old Oct 6, 2009 | 06:06 PM
ac419's Avatar
awesome thanks!
Old Oct 7, 2009 | 07:17 PM
no problem
Old Nov 14, 2009 | 02:10 PM
armon91's Avatar
did you add a middle seat when you took this out or why would you need to take it out?
Old Nov 15, 2009 | 06:15 PM
i swapped out the middle section from a graphite interior and replaced it on my stone interior
Old Nov 24, 2009 | 09:41 PM
stinkytofu89's Avatar
awesome
rezendvous420
May 31, 2020 01:26 PM
Frostbite91
Jul 27, 2015 05:25 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
