Big Problem with 06 G35 Coupe seats
Old Mar 29, 2013 | 08:17 PM
  #31
YaadiG35's Avatar
Can you manually move the seats? i am looking on a G coupe & the passenger can only go back and forth...forward or back
so can i push it back up or down?
Old Apr 30, 2013 | 03:05 PM
  #32
liamdimitri's Avatar
Originally Posted by topshotta97
06 G35 coupe 6 sp.. 50k miles. Passenger seat is stuck in the reclined position. Seat will not tilt forward. It moves back & forth on the Rail, but the back part of the seat will not tilt. Took it to dealer the stated warrany was out 13 days ago.. charged me for 2hrs diag.. Then tells me it is the switch and part is $3000... Stated switch is bad and they need to replace the entire seat cushion because the switch is inside of the cushion. Dealer stated if it was the drivers seat, then the part is only $85. I am livid. I might as well just put the $3000 on a new car and get a car with a seat that works. Has anyone else had this problem.
I had the same problem on my 05 coupe, luckily the Nissan dealer spotted it before I bought the car and replaced it free of charge. The seat wouldn't work they said because a larger man was checking out the car and broke the recliner. They had to replace the motor in the seat and "flip the switch?" they said to activate the motor..
Old Jun 14, 2013 | 04:12 PM
  #33
rcdash's Avatar
I would definitely look into aftermarket leather Recaro seats for $3k! My less complicated 04 coupe has no such auto recline, hence nothing to fail!
si_driver
Interior
Jul 25, 2015 09:22 AM
vstypicals
Jul 20, 2015 10:55 PM
brian_z
Jul 20, 2015 01:30 AM
attarday
Jul 15, 2015 04:03 PM
