Door lock quit working...
Old Oct 3, 2010 | 10:01 PM
Nismo G's Avatar
I just bought another G35 and today i was fixing a couple things on it. There was a rattle coming from the passenger side door so i took the panel off and it ended up being a loose screw. After removing the panel and putting it back on the door lock won't unlock and lock. I can feel it trying, but something is wrong. It worked before i took the panel off. I know before on my other G this had happened and i just toyed around with the actual cable and it started working again...any one have this problem before? Help
Old Oct 3, 2010 | 10:05 PM
alfhasg35's Avatar
your actuator might have gone out... bad coincedence..
Old Oct 3, 2010 | 10:17 PM
Nismo G's Avatar
You can here it inside the door when you press unlock and lock its just that the cable isn't moving...
Old Oct 3, 2010 | 10:32 PM
alfhasg35's Avatar
thats what happens when the actuator goes out.. u hear it WANTING to work.. it even moves the lock a little.. but doesn't have the strength or torque to open it.. or gas.. or whatever.. it sux .. happened to me a couple times already..
Old Oct 6, 2010 | 09:33 AM
Shakuya88's Avatar
I have that same issue right now. As it's getting colder it actually will work now but it's still slow, not snappy like it should be.
Old Oct 25, 2010 | 10:52 AM
Tri-GunSlingEr's Avatar
If you do a search for "Door Lock Fix" there is a nice DIY with PICS on a $5 fix buy buying a separate actuator taping it into your existing wiring. I did it on both doors to my coupe and it worked like a charm! It only takes about 20 mins per side.
Old Oct 25, 2010 | 10:58 AM
DG_coupe's Avatar
+1 saved me a lot of money doing this mod myself. did it to both doors and they are still working.
Old Nov 22, 2010 | 07:56 AM
RicoG35x's Avatar
This is one of many "quirks" of owning a G.. I had mine do a slow death... getting to the point where the door would NOT even lock/unlock manually!! It cost an @$$ load of cash to have the actuator, latch and "misc. hardware" replaced to get it right. While i was there bitching to the Service Dude about how if this is a known problem.. and SHOULD be considered a Factory Defect and covered by Infiniti.. he told me one guy kept putting it off until they couldn't get the door open to fix it... didin't ask how it turned out... so yeah.. bad design.. we pay the cost for it... same as the window actuators... JDM electricals... probably made in ENGLAND!!!
Old Nov 22, 2010 | 08:54 AM
GreenGoblin's Avatar
The goblin resurrection
Both of mine went out at the same time a couple years back.
Old Nov 30, 2010 | 04:27 PM
jutn35's Avatar
G35 Coupe
im gettin mine done at the dealers for around 420$ and no more than that by my friend, i dont really trust anyone else touching my car but him hahahah
Old Nov 30, 2010 | 04:47 PM
Frankieg35's Avatar
Omg are u serious!?!? Thats the last place u go..
Old Dec 6, 2010 | 03:32 AM
jutn35's Avatar
G35 Coupe
well i have no choice really ^ where would i go , i dont want to mess with my door / windows, i messed up the window alignment once , not going to do it again.
G35-R
Nov 7, 2015 01:21 PM
TNRocker
Sep 21, 2015 08:36 AM
douglas555
Sep 10, 2015 04:48 PM
jbmw002
Sep 3, 2015 08:42 PM
