Changing OEM shift knob ?
Old Oct 29, 2010 | 02:39 AM
jutn35's Avatar
G35 Coupe
Question Changing OEM shift **** ?
My shift **** on my G (AT)TAN)03) is starting to look ugly in looks and condition. I was wondering if its possible to buy an OEM G37 (AT) **** and put it on my G35
THANKS
Old Oct 29, 2010 | 03:08 AM
Beebo's Avatar
I believe the M45 shift **** will fit, here it is on a 05
Old Oct 29, 2010 | 09:45 AM
gary c's Avatar
Give our buddy Rick at Riverside Infiniti a call, see what's available to replace your shift **** 800-919-8130. Being one of our sponsors they give us wholesale discounts.
Gary
Old Oct 29, 2010 | 01:21 PM
jutn35's Avatar
G35 Coupe
Question
Thanks ^ i always hear rick is a great guy to deal with but one big question . What bout the button you have to push to go from P to other Gears ? what will be done with that?
Old Oct 29, 2010 | 02:00 PM
Beebo's Avatar
with aftermarket shift ***** there will be a button on the top or you push down on the ****
Old Oct 29, 2010 | 04:08 PM
jutn35's Avatar
G35 Coupe
But im not going with After market. I want to stick with OEM. Im going to see my mechanic soon and ask him if it can work.
FUUUUUUUCK ! 250$ at INFINITI of Tustin for the ****, im going to call rick for his prices later on
Old Oct 29, 2010 | 06:16 PM
Blue Dream's Avatar
I drove ttrank's car solo
This one needs some considerable work done on the shifter and **** to fit correctly.
Looks badazz though
Old Dec 3, 2010 | 02:15 AM
jutn35's Avatar
G35 Coupe
IM jw , since our AT have a button on the side of the ***** , can i just replace it with a oem MT knot, or do i need to get one with the button and connect it ?
Old Dec 3, 2010 | 01:20 PM
jutn35's Avatar
G35 Coupe
Bump , do i need to connect the button to the shift or can i leave it unhooked some how ?
Old Dec 3, 2010 | 11:44 PM
jutn35's Avatar
G35 Coupe
Old Dec 4, 2010 | 03:48 AM
G35 Dream's Avatar
If you get a stock M45 AT shift **** it will have the release button just like yours. Talk to Rick and see if it will connect without any modification though. Infiniti probably made everything the same so it should if you get one from the same year as yours. Or you could always modify yours.
Old Dec 4, 2010 | 02:07 PM
jutn35's Avatar
G35 Coupe
what year m45, bc im liking the EX35 ***** and they also have the button. but ill give him a call thanks
Old Dec 4, 2010 | 02:29 PM
WhosRich's Avatar
MT ***** will not work on AT period. You should look for an 06-07 AT **** if you're looking to oem upgrade.
Old Dec 4, 2010 | 03:29 PM
jutn35's Avatar
G35 Coupe
but are the connections the same though for the push button ^ ?
Old Dec 4, 2010 | 04:01 PM
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
Yes. It is just one **** to another. Just switch it out. There isn't a line or anything that you need to connect. The button for the ***** just moves down a lever that pushes down on top of the metal rod (no homo) that sticks out from the shift plate. It is essentially just plug and play. Very easy to do.
