FS[SoCal]: 2005 G coupe Driver side Window Motor (used)
Old Apr 29, 2011 | 02:22 PM
alfhasg35's Avatar
I have a used 2005 COUPE Driver side window motor..it will not work on a sedan.. i cleaned the carbon off the brushes last year and it went out again.. it works intermittently.. which means.. this is not a 100% functioning window motor you can use it as a core, or u can rebuild it by buying new brushes or whatever.. i opted not to clean it again and just bought a new one, although it happened to work right before i replaced it.
FOR PARTS OR REBUILD...
$50 shipped to lower 48 states..
Old Apr 29, 2011 | 11:29 PM
jayelleseven's Avatar
From: socal--not leavin this place, jus takin over it one venture at a time.
Can you explain what you mean by cleaning the carbon off the brushes? Is this inside the motor or a part that attaches to the window mechanism/part where the motor is set onto the door?
Old Apr 29, 2011 | 11:37 PM
alfhasg35's Avatar
there is a DIY on when your window motor stops working and how to repair it..
https://g35driver.com/forums/body-in...l-removal.html
Old May 13, 2011 | 02:25 AM
pythonjosh's Avatar
This still around Alf? I'll get it from ya.
This is the detailed tutorial on repairing the window motors.
https://g35driver.com/forums/interio...or-repair.html
Old Jun 3, 2011 | 02:06 PM
alfhasg35's Avatar
i still have it.. u got pm
mbe093
Lights
Oct 2, 2016 11:09 PM
Ludz
Lights
Mar 28, 2016 02:06 AM
will091195
Jul 27, 2015 09:19 PM
vstypicals
Jul 20, 2015 10:55 PM
attarday
Jul 15, 2015 04:03 PM
