Seat problem ?!?!?!?!
Old Sep 6, 2011 | 04:04 PM
MannyFresh's Avatar
Alright so earlier on today i decided to raise the back of my seat up a bit.
As i go to lower it down it wont even budge!
I looked under to see if there was anything wrong or if there was something from letting it go down, and nothing.
I have coupe seats in my sedan. My question is does anyone know what the problem is or how to fix that? Has anyone ever had this problem? Its very uncomfortable driving this way.
Old Sep 6, 2011 | 05:08 PM
jimmyboi860's Avatar
where are you from if you dont mind me asking?
Old Sep 6, 2011 | 05:46 PM
MannyFresh's Avatar
Miami
Old Sep 6, 2011 | 09:01 PM
MannyFresh's Avatar
Anyone???
Old Sep 7, 2011 | 09:36 AM
MannyFresh's Avatar
Views but no suggestions
Old Sep 7, 2011 | 10:06 AM
psedog's Avatar
Back in SD**
Check your fuses and seat wiring harness.
Old Sep 7, 2011 | 11:47 AM
MannyFresh's Avatar
That would be the fuse box inside the car correct?
Old Sep 7, 2011 | 12:02 PM
simpson's Avatar
If all the other functions work on the seat like it moves back and forth then most likely its the switch.
Old Sep 7, 2011 | 12:16 PM
MannyFresh's Avatar
Yea all of the other functions work.. Slides forward/back. Reclines up and down.
The switch that raises the bottom from also works.
Now the one for the back bottom I raised up all the way, when I click it to raise up there's a little tick noise, and when I go to lower it down no click and no go.
How do I go about fixing that switch?
Old Sep 7, 2011 | 12:57 PM
simpson's Avatar
Unless you are good with that kind of thing I don't suggest you take the switch apart. Its easy to do but not easy if you have never done it. You have to take the seat out of the car to do it.
Old Sep 7, 2011 | 01:09 PM
MannyFresh's Avatar
Not really cus it's actually uncomfortable for me. Iv removed seats before in previous cars so that shouldn't be a challenge. What would be a challenge is removing the switch etc etc.
Know where I can buy a switch?
Old Sep 7, 2011 | 04:05 PM
simpson's Avatar
What year were the seats?
Old Sep 7, 2011 | 04:08 PM
simpson's Avatar
Pm speck102 he has the switches for 03-04 coupe seats
Old Sep 7, 2011 | 05:36 PM
MannyFresh's Avatar
I honestly have no idea cus when I got the car they were already there.
And yep it's a bad switch. Started to mess with it a little to see if I can some how make it go down and as I did it did a little stall and that was it. And thanks will do
Old Sep 7, 2011 | 05:37 PM
MannyFresh's Avatar
How can you tell what year the coupe seats are?
