Seat works *but*...
Old Jun 12, 2014 | 01:03 AM
MarkhamX's Avatar
Seat works *but*...
I've searched but haven't found an answer to this specific issue:
(2006 G35x) the passenger seat moves forward and backward but only about 2 inches in either direction. It only moves forward that much because it's fully forward, and then will only slide back 2 inches and stops. So motor is fine. It's not one gear working and the other side isn't. Can't figure it out. I can remove the seat but not sure what to look for. If anyone has a suggestion I'd appreciate it.
Old Jun 18, 2014 | 08:45 PM
MarkhamX's Avatar
*bump* anyone?...
Old Jun 19, 2014 | 08:17 AM
vashawn's Avatar
Front gear
Old Jun 19, 2014 | 08:49 AM
LoSt180's Avatar
Is the switch bad? Mine would recline backward, but struggle coming forward, and it finally just wouldn't recline forward anymore at all. Picked up a used switch and all is well. Best way to confirm if it's the switch or motor is to apply 12V directly to the motor and see if it functions correctly.
Old Aug 15, 2014 | 10:58 PM
woodstar's Avatar
I have same prob in 04, up/down thigh adjustment. Goes up and stays there, so fuse ok, but just doesnt want to go down. Lousy driving position. Can't find anything on forums for a fix.
Old Aug 16, 2014 | 12:51 PM
MarkhamX's Avatar
It's likely the plastic gear. It's a 10 cent part (that sells on eBay for a lot more). Search for G35 Seat Gear.
Old Aug 16, 2014 | 09:55 PM
woodstar's Avatar
Is there a manual adjust? I have to import gear from US so will take a while. I'm in Australia, hard to get parts here.
Old Aug 23, 2014 | 05:00 AM
ATXmax's Avatar
Question
arora_g35
Apr 16, 2026 02:52 PM
wuppiedog
Aug 7, 2015 11:16 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
si_driver
Interior
Jul 25, 2015 09:22 AM
