Anyone fix their flashing airbag light by replacing the seats?
Old May 12, 2017 | 07:13 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
My driver's seat has a small tear in it. Might just go ahead and replace it once I find one in better shape than mine. And I'm considering grabbing the passenger seat since either the airbag module in it is bad or the connections are.
Anyone change seats and either have that fix the airbag light...or cause it to flash after swapping seats?
Old May 13, 2017 | 12:23 AM
Edgarc6789's Avatar
Its a easy fix to reset turn the key to acc
Once the airbag light goes off turn the key off
Repeat 3 times
Then turn the car on
Old May 13, 2017 | 01:34 AM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
I was thinking of a more permanent fix than a reset...
Old May 15, 2017 | 05:56 PM
edubb11's Avatar
I fixed my passenger airbag light issue by wrapping zip ties around the connector. There's a TSB for the issue and the fix involves removing and replacing the connector, however the 2003 and maybe 2004 sedan wasn't included. The zip tie trick has worked for me for over a year now.
Attached Thumbnails Anyone fix their flashing airbag light by replacing the seats?-2017-05-15_18-18-04.jpg
