Tired of the seat control switches digging into your leg ?
Old Apr 10, 2005 | 08:07 PM
Sickone's Avatar
Well the mounting of the set control, switch cluster is horrible.
It tends to cut into your leg on long rides. I had my seat out, and resolved this.
In short I bend the switch cluster out at an angle more in line with the contour of the seat. Man is a lot better now.
If you are interested I did a quick tutorial.
http://www.descentbb.net/videotest/seatmod.htm
Old Apr 10, 2005 | 10:49 PM
WRAH's Avatar
WRAH
You know your dealer will remove the hard plastic (control liner) and add more padding!
Old Apr 10, 2005 | 11:06 PM
Sickone's Avatar
I had heard they had a TSB, but had not heard any thought it was any better.
The plastic is not the issue, and padding wouldn't really help.
The metal portion is where the problem is, and it needed to be moved.
It was so worth it....
Fireman07603
Aug 9, 2015 06:00 PM
wuppiedog
Aug 7, 2015 11:16 AM
itschuckster
Jul 25, 2015 08:07 AM
vstypicals
Jul 20, 2015 10:55 PM
