RHD Battery Cover
Old Sep 10, 2007 | 04:26 PM
  #31
WILLIE BEANS's Avatar
I Plan On Getting The "stillen" Master Cylinder Brace ..would The Cover Or The Brace Itself Get In Each Others Way .???
Basically Im Asking If The Cover Would Fit Over The Brace ..
Old Sep 20, 2007 | 09:44 PM
  #32
chobbsnh's Avatar
I just installed mine within the last 15 minutes. I have only 2 comments and hopefully they will help those with 06 coupes.
1) Leave the front lip/rib (no need to cut it off). Just trim off all the material in front of the lip/rib. The weather strip will fit over both the sheet metal and plastic very nicely.
2) The upper left hole on the cover actually sits on a piece of plastic that you can drill a hole through and install one of the plastic plugs.
The cover is very secure once installed.
Old Sep 28, 2007 | 06:04 PM
  #33
05GCOUPE6MT's Avatar
Originally Posted by OCG35
RHD = Right Hand Driver... JDM = Japanese Domestic Manufacturer... the driver right side.
BTW - for those interested, I came up with a very stealth OEM look bracket for the firewall side of the cover - the cover piece itself has no connector to the firewall area.
It's simply the white bracket that the pin-clip snaps into - same one found on the curb side battery cover - its the clamp on the inside of the OEM cover that has two nipple clips through the inside of your engine compartment. Just look at your existing battery cover and locate the pin clip on the inside towards the engine. That’s the clamp you want to get from your local dealer service department (about $2 I think). Simply clip off the two nipples on the side (you can keep them but you don’t need them) - then use a dremmel (sp?), or a small rat tail file, or even a drill bit to etch a small curved opening at the bottom of the clamp (to create a notch slightly larger than the brake lines running along the firewall - this is where you are going to place the bracket. The original length is perfect fit to rest on the lines - then simply install your cover as indicating in Andy’s DIY and insert the pin clip. There is no tension or pressure on the lines, it will not cause any harm.
Now you have an OEM look/fit that is functional. The cover is perfectly secure in all areas around the edges. Hope this made sense to everyone... Pics are attached.
Ya know what I did. You see that plastic piece you installed. I just got a piece of the Block Window Foam and put it in that same spot. It wedges between the lines and top. I left about 1/25 inch overlap which the RHD cover sits on.
Old Oct 5, 2007 | 11:03 PM
  #34
civic4982's Avatar
thanks for the DIY. I just did mine. Worked great!
btw, maybe a mod should put this in the DIY section?
Old Oct 5, 2007 | 11:04 PM
  #35
civic4982's Avatar
+1 I left the lip on like you said on #1 and it worked great.
Haven't tried #2 yet but sounds like a ogod idea!
Old Oct 24, 2007 | 04:59 AM
  #36
ShanesG's Avatar
hmmm well **** i did mine totally different
i cut about 1/2" of the metal sheild, amd made it look just like the other side, no cutting of the battery cover except for a little at the point that points toward the middle of the bay....oh well both work
EDIT: ok i guess i did it the same way as the guy above lol, only o donno how you got one of those plastice piece to fit in the hole i just put the plug that you take out, for the new plastic piece and squeezed it in the hole
Old Oct 26, 2007 | 02:41 PM
  #37
G35Papa's Avatar
Thumbs up
Andy
Your thread came in handy once again
Off to install my cover now.
Thanks for the write up
Old Dec 27, 2007 | 10:48 AM
  #38
Sportcoupe35's Avatar
Ahhh so this is how I install it. Thanks for the DIY!!!
Old Feb 7, 2008 | 05:02 PM
  #39
louieallthetime's Avatar
any idea on where to get the rubber piece to put on top? mine car oddly doesn't have one..
Old Apr 21, 2008 | 01:24 AM
  #40
RedG's Avatar
<--12 More Years
thanks for the clear simply DIY, just used it after spending half an hour too trying to get it on.
Old Apr 21, 2008 | 05:47 PM
  #41
strife's Avatar
Thanks for the DIY
Old May 2, 2008 | 11:02 PM
  #42
Beebo's Avatar
thanks for the DIY...
Old Jun 4, 2008 | 02:39 PM
  #43
radio5boro's Avatar
thanks for the diy..
Old Jul 16, 2008 | 01:18 PM
  #44
benwaballs's Avatar
just did mine w/ your help thanks man
Old Jul 16, 2008 | 05:16 PM
  #45
dlwns's Avatar
anyone had a problem where after the trimming and installation, the hood wouldn't close perfectly aligned on the right side?
The right side of the hood was slightly lifted and not aligned w/ the fender.
After few tries of sitting the molding perfectly on top of both metal & battery cover edges, i was able to get the hood closed without the lift.
