Piaa HID 6600k Vs Philips Ultinon 6000k
Old May 23, 2006 | 12:16 PM
holyfrickster's Avatar
Hey Guys maybe you can help me out a bit, and give me some of your imput on this subject. I am trying to compare each of these bulbs
PIAA HID SUPER COBALT HID 6600k
AND
Philips 6000K Ultinon D2R
I have seen many of the Philips Ultinon Bulbs around these Forums, and was very impressed and liked them a lot, but I saw the PIAA's and haven't seen those here. So Lets get some imput On these bulbs
Here are a few specs on each bulbs
Price: Roughly $389.95 (Depends Where You Go)
6600k Color Temperature
The PIAA Super Cobalt HID bulb is the highest rated bulb on the Kelvin scale available on the market today. These make a great upgrade from normal factory HID (3800 Kelvin) to 6600 Kelvin and produce a clean, clear, crisp beam. Only the highest-grade materials are selected for use in these products and to ensure your complete satisfaction, every PIAA bulb is 100% tested at each step in the manufacturing process. Absolutely nothing is left to chance!
Price: Roughly $230.00
6000K color temperature
Contains indium iodide to create extra blue light
This Xenon bulb is for Reflector Headlights
(Description Taken Off Amazon)
This is the best Xenon Bulb on the market. Providing the best lumen and color combination. Don't be fooled by the higher Kelvin rating Xenon Bulbs. They are very weak when comes to light output. This Xenon bulb is for reflector headlights. This is for a pair of Philips Ultinon 6000K D2R Xenon Bulb made in Germany with 1 year limited warranty. The Ultinon family of automotive discharge lamps was introduced by Philips to meet the significant aftermarket demand for head lighting units having a 6000K color temperature, higher than the standard 4100K type. The 4100K lamps can produce headlight beams of distinctly different colors depending on the design of the optical system into which they are incorporated. Many HID headlights now employ projection lens systems which capture all light from the lamp, thoroughly homogenize it, and then project a uniform color beam out through a mask and lens. Color variation from one projection system to another is minimal, the only difference sometimes occurring around the edge of the beam where chromatic aberrations from imperfect lenses may give the beam a purple colored lining. However with 4100K lamps in reflector style headlights, the beam will often be found to have a yellow or green color in the upper areas. The light here originates from the lower portion of the reflector. Light hitting that part of the reflector must pass through the lower half of the arc tube in which the pool of yellow-colored molten metal halide salts resides, and much of the blue light is therefore filtered out in this area. This greenish-yellow tinge is considered to be most unsightly in the aftermarket, a bluer light being strongly preferred. To satisfy this market Philips introduced this higher color temperature 6000K lamp whose dose contains indium iodide to create extra blue light. This is for a set of 2 Philips Ultinon Xenon Burners.
IMPUT
Old May 23, 2006 | 12:20 PM
Triji's Avatar
I have the Piaa 6600K's and I LOVE EM!
Attached Thumbnails Piaa HID 6600k Vs Philips Ultinon 6000k-dsc01852.jpg   Piaa HID 6600k Vs Philips Ultinon 6000k-dsc01867.jpg   Piaa HID 6600k Vs Philips Ultinon 6000k-dsc01872.jpg
Old May 23, 2006 | 12:52 PM
WRAH's Avatar
WRAH
If you must go Philips 6000K Ultinon D2R. PIAA are not worth the extra money.
1001's Avatar
definitely get the PIAAs. i had them on my car and they look amazing. kinda gives a purple-ish look to it. i had 3 friends get them after i did. i wish they made some D1S but unfortunately they didn't cuz i missed them. $390 seems kinda high. i got mine at a local shop for only $290.
Old May 23, 2006 | 07:42 PM
g35rcr's Avatar
piaas do tend to burn out quicker...i like my ultinons esp since i paid 200 for a new pair
Old May 23, 2006 | 07:44 PM
Ok Cool, do you know of any bulbs that will match the Piaa's good? Because I haven't seen any piaa bulbs that looked like that
Old May 23, 2006 | 09:19 PM
g35rcr's Avatar
plasma gtx
Old May 23, 2006 | 11:02 PM
WRAH's Avatar
WRAH
Kelvin Style006
May 23, 2016 03:47 AM
lil beezy
Lights
Nov 16, 2015 02:52 AM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
MrIP35
Oct 25, 2015 11:13 PM
twentyeggs
Sep 11, 2015 03:58 PM
