LED turn signals
Old Jun 27, 2006 | 12:26 PM
GeorgeM's Avatar
LED turn signals
Anybody try to swap these for the incandescent turn signals in their '06 coupe? Surprised that I couldn't find anything in a search.
http://cgi.ebay.com/ebaymotors/2-Bul...5102QQtcZphoto
Old Jun 27, 2006 | 12:28 PM
g35newbps2's Avatar
I have them. Tested them out and they look very bright crisp white. I haven't put them in yet because I guess you have to take off the bumper to get to the light. that sucks.
Old Jun 27, 2006 | 12:44 PM
GeorgeM's Avatar
Take the bumper off for a turn signal bulb? Holy cr@p.
This site has some info about using LEDs vice regular bulbs and the issues they may cause with the car's "bulb burned out" warning due to low current draw. Was curious if anyone had issues. Also talks about getting LEDs the same color as the lens for max brightness.
http://www.superbrightleds.com/carbulb-notes.htm
Old Jun 27, 2006 | 05:46 PM
IvoryGT's Avatar
u dont need to take the front bumper off. you need to take the wheel well off. you can reach behind the light and twist off the turn signal to replace it.
Old Jun 27, 2006 | 06:14 PM
extreme4377's Avatar
Lexus IS350
I replaced my front turn signals with some PIAA's that have a silver outside and light up amber. Takes the yellow out of the lights when the signals are off. Cleans it up a bit
http://www.eautoworks.com/html/ORD-1-1-1-906.cfm
Old Jun 27, 2006 | 06:28 PM
GeorgeM's Avatar
What about the rear lights?
Old Jun 27, 2006 | 07:03 PM
M4Gunner's Avatar
Ive done LED replacements both, front and back. they are great. there is two things that are different.. 1) in the front, your blinkers will no longer light up unless being used. I.E. no more running light. it will only light when blinking. (personally, this was one of the things that i was going for. IMO it cleans up the front end.)
2) the speed of your blinkers will increase. it may seem a little fast at first, but you get used to it. When hazards are on, they blink at the factory set speed. the bright crisp light is more than worth it.
BTW, i did NOT use the LEDs in the listed Ebay ad.
Old Jun 27, 2006 | 07:23 PM
g35newbps2's Avatar
just to confirm it is correct that the fender protector is all that is needed to replace the lights. I had someone else post that the bumper needed to be taken off so that scared me away from doing it. Well I got the service manual and just the fender protector both back and front need to be taken off. Unscrew the plastic housing and undue the mounting bracket.
sorry for any confusion. I'm doing mine tonight.
Old Jun 28, 2006 | 01:42 AM
shimmy's Avatar
how do they look? Are they bright enough during the day? Do you have any pics? Thx!
Old Jun 28, 2006 | 08:05 AM
G35 Mass's Avatar
You just need to pull back that black plastic fender material to access the rear of the light.
Theres also a thread going about how to stabalize the speed of the blinkers. Becasue the draw for LED's is SO low, the flasher thinks one of the bulbs is not working, and starts doing its seizure flash, which is annoying and makes cops think you have a blinker out...
Old Jun 28, 2006 | 11:19 AM
GeorgeM's Avatar
The superbrightleds web site has a load resistor kit (you'll need one per bulb) to trick the system into thinking the LED is a higher draw incandescent bulb. This should stop the fast-flash or any bulb-out warnings.
Old Jun 28, 2006 | 11:39 AM
Scootch's Avatar
prob will work out
Old Jun 29, 2006 | 05:58 AM
M4Gunner's Avatar
scootch has seen my LEDs.. he can tell ya! theyre the bomb! lol
George, where in Va Beach are you? i used to live there.
Old Jun 29, 2006 | 08:23 AM
GeorgeM's Avatar
I live south of Oceana, just NE of the courthouse, but work at Little Creek now. There's quite a difference in commuting time - Oceana vs. Little Creek.
