G35c HID bulb Questions?
Old Jul 5, 2006 | 12:09 PM
G35-G35's Avatar
I was wondering if anyone knew a easier way to swap out the stock hid bulbs with some new ones without removing the front bumper????? i was also thinking about getting a set of JDM 8000k bulbs of of ebay from motoring max.... I had these same exact bulbs on my is300 and they are still running. they have lasted for ten months with no problems. im just curious if anyone has had expierences with this bulb on the g35 coupes?????
Attached Thumbnails G35c HID bulb Questions?-jdm2.jpg   G35c HID bulb Questions?-jdm-3.jpg   G35c HID bulb Questions?-jdm1.jpg
Old Jul 5, 2006 | 12:18 PM
TheKnite's Avatar
I didn't have any experience with this bulb, but I believe you can change it the same way you change the fog light bulbs, through the wheel well, without removing the bumper. Somebody should confirm this though.
Old Jul 5, 2006 | 12:21 PM
g35rcr's Avatar
jack the car up, take the wheel off, pop out the plastic rivets, peel back the plastic lining, then you have total access to the lights - just be careful when handling them
Old Jul 5, 2006 | 01:44 PM
vhtran's Avatar
Same thing with the above thread, unless u lazy taking off the wheel then give u a little more time to work, but taking them off make it way easier and save u a lot of times. Have changed a few pairs already. =) Have fun!
Old Jul 5, 2006 | 04:15 PM
wolfwood's Avatar
Same here. The time and headache save in taking out the wheel is well worth the few minutes to loosen the nuts, jack up the car and remove the wheel and reverse the process once the light is changed.
Old Jul 5, 2006 | 04:38 PM
WaLLy's Avatar
if I'm changing both bulbs, i'd rather take the whole bumper off! i've done it a few times already!
and why go with 8000K?? show car?? i wouldn't be running those..
Old Jul 5, 2006 | 04:52 PM
g35rcr's Avatar
ive changed all my bulbs through the wheel well, its not hard
Old Jul 5, 2006 | 08:51 PM
G35-G35's Avatar
i had them before there not to bright but there brighter than stock thats for sure and give off a nice bluish/white tint
Old Jul 5, 2006 | 09:18 PM
IvoryGT's Avatar
by brighter you mean appears brighter to your eyes. They give off far less lumen than factory or 5000K. You are sacrificing about 30% of lighting performance for the color.
Old Jul 5, 2006 | 09:31 PM
WaLLy's Avatar
+1
Old Jul 5, 2006 | 09:34 PM
xkoraznboix's Avatar
20 Year Member
if you want ur lights to have more blue... go up to 6k bulbs... after 6.5k you loose visibility...
Old Jul 5, 2006 | 09:39 PM
G35-G35's Avatar
Thanks Everyone Do yall have any pic of hid bulbs on the coupes
Old Jul 5, 2006 | 11:10 PM
IvoryGT's Avatar
5000K on top 4300K bottom
Jusseth
Sep 13, 2020 12:25 PM
as25656800
Aug 9, 2015 07:25 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
attarday
Jul 15, 2015 04:03 PM
