Custom Clear Corners
Old Aug 16, 2006 | 07:02 PM
Skaterbasist's Avatar
Retired SuperMod
Originally Posted by aHero4Eternity
im just trying to clear up the fact that youre not going to be buying HIDs..
LEDs may flash quicker if you use them for your turn signal..
but unless you have the sidemarker turn signal mod you shouldnt have a problem..
Can you clarify your last sentence for me?
I appreciate your help
Old Aug 16, 2006 | 07:09 PM
Calvin's Avatar
Overglorified Altima
since you dont know what im talking about you probably have nothing to worry about
anyway..there is a mod that you can do to make your sidemarkers blink with your normal signals..
if you use LEDs in your signals you risk them flashing/blinking too fast
Old Aug 16, 2006 | 07:10 PM
Calvin's Avatar
http://digitalwheelz.com/diy/sideMar...ker/index.html
Old Aug 16, 2006 | 07:15 PM
Retired SuperMod
Well since I am getting LED's in my clear corners, I guess I do have to worry about it.
Your making me get even more worried after seeing that DIY tutorial.
I guess Ill just have to hope my LED turn signal will blink/flash at the same rate of speed as the other lights (ie. tail lights)
Old Aug 16, 2006 | 07:18 PM
izmir41500's Avatar
G35driver Addict
To clarify:
You do not have to worry about the clear corners flashing faster than your headlight turn signal if you do not do the turn signal mod with your corners.
If you don't do the mod, the stock clear corners are always on.
Old Aug 16, 2006 | 07:22 PM
Retired SuperMod
Originally Posted by izmir41500
To clarify:
Ah I see.
Thanks for clarifying
Old Aug 16, 2006 | 08:22 PM
Calvin's Avatar
lol sorry for the confusion..
Old Sep 13, 2006 | 10:35 PM
DannoG35's Avatar
Hmm...
You could do some overlays. Most common is to put them on the jdm clears. If you looking for an interesting or particular design I may be able to help.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
ZoominG35
19 Inch
16
Oct 30, 2015 05:44 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
cmesidewayz
Sep 29, 2015 09:28 PM
