Clearance strip problem (please help)
Old Sep 1, 2006 | 05:40 PM
ptown44's Avatar
Question Clearance strip problem (please help)
I tried a search already but couldn't find anything similar to the problem I'm having.
One of my clearance strips went out about 6 mos. after I got my car. I left it like that for a while and then had the dealer replace it when my car was in for some brake issues. As far as I can remember it was working okay but then I replaced them with leds (V-Leds.) They look really good but the same clearance strip went out again.....or I thought it went out. When I was drving the other day my friend said it was flashing.....like I had a freakin strobe hooked up!
I guess the bulb could be loose but the fit was pretty tight and since its the same clearance that went out before I have my doubts.
So my question is do I try and contact V-Leds about the bulb or does it sound like I have something wrong in with the wiring to that clearance?
I'd appreciate any help or ideas
Thanks
Jon
Old Sep 4, 2006 | 06:54 PM
Need4SPEED05's Avatar
Try messing with the bulb first to see if it'll blink. Also since they are LEDs you may want to pull it out and turning it so the contacts hit the opposite of before then put it back in to see if they light back up. It may just be a loose connection if your friend says it was flashing. Also try putting the old regular bulb back on to see if it will work.
Thebaws11
Jul 2, 2021 11:36 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
wuzz-upp
Oct 3, 2015 04:21 PM
mattdg35
Sep 14, 2015 11:28 AM
Jnm07
Sep 5, 2015 01:16 AM
