Help - Headlights not working after battery change
Old Oct 26, 2006 | 12:01 AM
Mr Fun's Avatar
Long story short:
Saturday - both regular ol' headlights (and car) working fine
Sunday morning - dead battery, car wouldn't start
Sunday afternoon - high quality battery replacement (Sears, battery only 15 months old, under warranty)
Sunday night - headlights not working, had to drive home with only the fog lamps / high beams
What am I missing here? I don't see any fuses labeled "headlights", I disconnected and reconnected the battery, I played with every switch & toggle I could find.
And, of course, I've spent hours checking the g35driver forums with no answers.
Any ideas before I take it to the dealer? Thanks.
Old Oct 26, 2006 | 08:23 PM
Curt G's Avatar
There's a fuse box as well as a heavy duty relay box right next to the battery. Did you check both of these? You will have to remove the surrounding plastic piece above the battery to get to them (not just the rectangular battery door). Then, for the fuses, there's a big black plastic cover right next to the fender that needs to be removed. The second one is a smaller rectangular box that has another black plastic cover on it (it's the one in front of the battery).
Hope this helps.
Old Oct 27, 2006 | 05:10 PM
Mr Fun's Avatar
They're all good, unfortunately
Thanks for your reply though!
Old Oct 27, 2006 | 06:28 PM
old_s13's Avatar
not enough amps to startup the xenon ballasts. battery either needs charge or your alternator isnt supplying enough charge.
chinee
Jun 10, 2024 07:48 PM
andyg35c1
Aug 29, 2015 03:37 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
attarday
Jul 15, 2015 04:03 PM
