PIAA Plasma Ion Yellow Fogs
I just found a set of H-4 that I bought a while back. They are by MTEC Racing Says: 12V 100/90W then just below that it says: 170/160W and some stuff I can't read.
Further on down it says: 3,300K I assume thats the color temp and "Golden style"
I may give them a try, but it's such a PITA to change them.
Further on down it says: 3,300K I assume thats the color temp and "Golden style" I may give them a try, but it's such a PITA to change them.
Here is the best pic I have. It's my S2000 projectors with Philips 6000k bulbs and the third shot is projectors and the H4 2500k (note they were not aimed yet, this was during my projector mod.
I don't have them anymore, took them out when I did a TL bi-xenon lower projector mod.
Originally Posted by jimmyc13
Texasscout - is the process the same as changing the clearance bulb? remove the fender liner & reach in w/ the hand? Or does that not work?
Yes it's the same, but the bulbs are hard to change if you have big hands. If you have the equipment and are willing to do it, jack it up and remove the tire and inner fender.
Originally Posted by fabulustt7
^where did you buy them?
G35VSHNG37
Sep 10, 2015 01:54 PM
