06 Projector retro 2.0 teaser
Finished!!!!
Night shots
Housing
That's all folks...
Update...messed with the projector a bit for better color/cutoff....
Factory 06 projector!?
More teasers!
Final testing..ughh
The color is just reflection from the flash, not the headlight itself.
Night shots
Housing
That's all folks...
More teasers!
Final testing..ughh
are you gonna be using a clearance strip from an 03-05? the cutout on the housing looks stellar
Thanks, I took extra care to cut the strip out, I will be using only the clear plastic part of the older headlights, initially I was going to make my own but realized that the plastic wasnt uniformly clear.
yeah that's what i was asking about (the stock plastic piece)...everyone here has seen your work so i don't think for a minute you'd be using the stock lighting behind the clear plastic
...can't wait for the end results
Originally Posted by IvoryGT
^ Rochester
^^ Eric wanted it this way.
I think it turned out really well.
Originally Posted by mx22o
damn i want you to make me one.. how much are you charging?
PM me.
and yeah they are Klumzyee's, he had a mis-hap so I had to fix it and took the chance to add a few things here and there as well as touch up on few things.
6 projectors?
