'06 Passenger Light Keeps Going Out.
Old Jan 26, 2007 | 12:19 PM
Mike_Deezy's Avatar
the connection keeps coming loose and i would have to push it back in every so often. I know a few people have this problem if not everyone, but is there anything that you guys have done to keep it from coming loose?
Old Feb 1, 2007 | 06:48 PM
paul721's Avatar
i had the exact same issue....here's the solution......there is a yellow ground wire that plugs into the back of the harness......what happens is the connector opens up and as you drive, it comes loose and comes off......
all the you have to do is squeeze the connector together gently with a pair of pliers so that when you slide it on , its tight.....give it a try
Old Feb 1, 2007 | 07:00 PM
Mike_Deezy's Avatar
Thanks, I will give this a try when I get home. Do I have to do this from time to time or just this once?
Old Feb 2, 2007 | 08:32 PM
paul721's Avatar
you only have to do this once....make it really snug.....however you will have to take off the fender liner to get access to it because it sits at the bottom on the harness that you cant get to from the top. ...good luck
Muski_G
Dec 1, 2023 11:11 AM
wonderizm
Sep 24, 2015 03:09 AM
