hid kit for 2006 sedan
Old Apr 8, 2007 | 10:56 PM
roff's Avatar
i want to get a hid kit for my g35 sedan
does anyone know what size bulbs or kit whatever i need?
thanks
Old Apr 8, 2007 | 11:05 PM
chinaman_87's Avatar
kits usually cause a lot of glare which means you'll **** alot of people off on the road.Try retrofitting projectors into your current setup? you can get more info at hidplanet.com
Old Apr 8, 2007 | 11:56 PM
ttrank's Avatar
Grocery getter
Your 06 sedan didn't come with HID's? I thought it was standard on all the G's after 2004.
Projectors are the way to go for more light and a better look without bothering oncoming drivers.
Old Apr 9, 2007 | 01:24 AM
psedog's Avatar
Back in SD**
I think he means the fog lamps. Which were always halogen's.
Old Apr 9, 2007 | 02:16 AM
ttrank's Avatar
Grocery getter
I would not put a HID kit in the fogs. It will create way too much glare for other drivers.
Old Apr 9, 2007 | 03:11 AM
psedog's Avatar
Back in SD**
Why else would he want it if he already has it then? Like you said every G35 after 2003.5 has HID's
Old Apr 9, 2007 | 08:44 AM
killerlexus's Avatar
it would look more like you have your highbeams on, then fog lights.
Old Apr 9, 2007 | 12:42 PM
4 Door Skyline's Avatar
but what if you use d2r stlye bulbs (the ones with the little glare shield bonded to the glass on top of the bulbs)?
Old Apr 9, 2007 | 01:47 PM
redlude97's Avatar
D2R bulbs are supposed to be used in conjuction with relector housings that were made specifically for HID, such as the low beam bowls on the sedan/03-05 coupe. Installing an HID kit into a halogen reflector WILL cause glare because they aren't designed for it. Don't make your car more dangerous to others just to get that "cool blue" look
Old Apr 10, 2007 | 12:18 PM
roff's Avatar
how would it make it more dangerous when its an option for g35s?
i thought it was an option and only came standard on the 06 coupes and 07 sedans and coupes
Old Apr 10, 2007 | 02:24 PM
redlude97's Avatar
I'm talking about putting a kit into your foglights, as the others are talking about
Jusseth
Sep 13, 2020 12:25 PM
nickmcc123
Lights
Oct 7, 2017 12:18 AM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
julian.dion
Lighting
Jul 29, 2015 12:47 AM
