Side Marker Fuse Blown
Old Oct 3, 2012 | 09:15 AM
  #76
DVG's Avatar
DVG
^Welcome to the forum, this isnt the best place to be asking that, but Ill answer as best I can:
There is a fuse box in the drivers side footwell on the left, behind the battery, and I think there is one more under the hood but I cant remember where it is.
Old Apr 22, 2013 | 11:09 PM
  #77
ImElvis's Avatar
I'm not sure if this is a fuse issue or not, but both of my sidemarkers completely shut off randomly. It's never both at the same time, it's one or the other side that goes off and doesn't turn back on until some sort of miracle happens. Even if I signal or use the hazards, it still won't light up or blink. Front and rear turn signals are fine. Just the sidemarkers. I tried swapping out the bulbs when it happened, no change. Yesterday the driver one was off. When I garaged my car last night I noticed in a reflection that it had turned back on
Is there such thing as a loose fuse? I keep forgetting to, but I'll try to remember to try the multi-meter on the wires next time it goes off. Anyone else have or have heard of this issue?
Old Jan 24, 2015 | 04:37 PM
  #78
hardlock's Avatar
I realize this is an old thread but I've searched everywhere and can't find more on this subject. I have a 2005 coupe where everything works except sidemarkers. Checked fuses behind battery and all ok but none specifically for the sidemarkers?
Before I start pulling wheel-wells, thought I'd be sure I wasn't missing something. Also if I do need bulbs, what are stock ones for an '05? Thanks much!
Old Jan 24, 2015 | 05:47 PM
  #79
PhoenixG35's Avatar
it's called tail lamps fuse. behind the battery
Old Jan 24, 2015 | 06:59 PM
  #80
Urbanengineer's Avatar
IPDM-ER
Intelligent Power Distribution Module - Engine Room
That is where your missing fuse is . If you have projectors you might notice that the city lights are out too!
Old Jan 24, 2015 | 10:35 PM
  #81
hardlock's Avatar
IPDM-ER - got it - box behind the battery... fuse not missing, just not blown and tail lights work fine.
"City lights"? Is that for Canada maybe? I'm USA and only see high, low, fog, parking and turning lights mentioned besides "clearance lights". No projectors I know of.
Car is '05 stock to my knowledge and manual only says xenon for headlights.
Must be bulbs then?
Attached Thumbnails Side Marker Fuse Blown-img_3389.jpg   Side Marker Fuse Blown-lights-diag.jpg
Old Jan 25, 2015 | 02:10 AM
  #82
Must be bulbs then?
Yes sorry it is for the clearance lights. You have the reflectors. Do those clearance light strip lights work or are they bad too? If they are bad that is your fuse.
Old Jan 25, 2015 | 04:07 AM
  #83
hardlock's Avatar
I'm lost again. I have no clearance lights working. The tail light fuse is fine and the tail lights work. All other lights are okay.
Old Jan 25, 2015 | 11:10 AM
  #84
Side marker are on the side, clearance are inside the headlight, are we clear on that much ?
Old Jan 25, 2015 | 04:34 PM
  #85
hardlock's Avatar
Opps, sorry, I mistakenly referenced the side markers in 1st post but meant the clearance lights. My bad.
Clearance lights in/op, tail light fuse OK. Any other fuse it could be? Thanks!
Old Aug 6, 2015 | 02:10 AM
  #86
dominate's Avatar
My sidemarker lights, parking lights, tail lights, and license plate lights won't turn on. This happened right after I replaced my parking lights. Unfortunately the OP's pics don't work anymore, does anyone know how to fix? Does it sound like a fuse problem? Do I check the fuse box behind the battery?
Old Aug 6, 2015 | 10:58 AM
  #87
Wrathernaut's Avatar
Gentle Manne of Leisure
Yes, it sounds like a fuse problem, check the fuses. If one's blown and it blows immediately after replacement/testing, you'll need a lot more in-depth diagnosis to find out what's causing it to blow.
flytim3
Jul 29, 2016 10:17 PM
TheBay
Aug 27, 2015 05:08 AM
realtalk21
Jul 20, 2015 09:07 AM
wylin
Lights
Jul 18, 2015 06:12 PM
