another blacked out headlight post
Old May 6, 2007 | 09:38 PM
empfl's Avatar
did you have any previous work with paint/ or diy jobs? or did you just pretty much wing it?? great job.. very clean
Old May 6, 2007 | 09:39 PM
khsonic03's Avatar
Looks good...I've got some pics coming too of a projector retro/blacked out housings/halo's. Silicone usually isn't good for resealing the headlights because as it dries, it releases agents that can cause fogging in the headlight. Did you have any problems with that?
Old May 6, 2007 | 10:42 PM
OCG35's Avatar
how do you re-seal?...
Old May 6, 2007 | 10:44 PM
LILShiraz's Avatar
how long do you bake it, and what temp? and then how do you re-seal?
Old May 7, 2007 | 12:10 AM
killerlexus's Avatar
i never had problems using silicone on any of my previous projects.
Old May 7, 2007 | 02:10 AM
ttrank's Avatar
Grocery getter
I have used silicone on mine the last 3 times they have been open with no problems.
Old May 7, 2007 | 08:48 AM
ron4row2's Avatar
Light look good. Nice job.
Old May 7, 2007 | 09:18 AM
Scootch's Avatar
nice one man
Old May 7, 2007 | 11:58 AM
khsonic03's Avatar
I used silicone in mine to affix the shrouds for the projectors, and I used silicone to adhere the halo's, but that was prior to re-sealing the headlight, so the silicone had time to fully cure. I resealed mine with the stock butyl sealant by baking it at 225 for 12 minutes and then pressing the pieces back together. ttrank, did you reseal the whole headlight with silicone, or did you just use silicone for attatching the halo's? I guess I don't understand how you guys removed all of the stock butyl sealant. That stuff is like gum.
Old May 7, 2007 | 12:32 PM
ttrank's Avatar
Grocery getter
I used a small dab of silicone to hold the halos and JB weld on the shrouds.
I put a line of silicone in addition to the stock glue and heated, pressed and re-installed the screws. You can always use silicone but keep the bulb access covers off while it cures if you need extra peace of mind.
Old May 7, 2007 | 01:14 PM
RocketG35's Avatar
Why do I bother to DIY???
Looks good. I take it you sanded the chrome off? What grit did you use?
Old May 7, 2007 | 03:55 PM
just heat up the headlight housing after you remove the lense, then you scrape off the factory glue with a flat head screw driver. its going to take like 3 times to heat and scrape off the gummy glue. its like rubber cement not hard just time consumeing. then i just ran a bead of silicone and presto.
you dont have to remove the factory glue. just heat the 2 halfs in the oven and press and screw them together. the OEM screws will help to seal the 2 halfs together.
dam ttrank, your projection & angel eyes are sweet.
Old May 7, 2007 | 05:22 PM
ttrank's Avatar
Grocery getter
Thanks!
Here is a better pic in the dark. I'm always happy to be a picture *****.
They are dirty but you get the idea.
Old May 7, 2007 | 06:43 PM
Floyds_racing's Avatar
I just bought the paint and a heat gun to do mine!!
Old May 7, 2007 | 07:02 PM
  #30
ttrank's Avatar
Grocery getter
Just put em in the oven. Works great!
