Brighter white in clear side markers?
Old May 26, 2007 | 07:22 PM
samecraig's Avatar
My first mod on this car: clear jdm side markers. But the stock "white" bulbs actually look yellow. What's a brighter side marker bulb you guys use so the markers more or less match the headlights?
Thanks...
Old May 26, 2007 | 07:48 PM
FaDz's Avatar
VIP
go buy some LEDS ... i have eurolite leds...
Old May 26, 2007 | 08:02 PM
sfgr415's Avatar
I purchased "white" V-Leds. They are more blue than the stock HID's, but they look good.
Old May 26, 2007 | 08:06 PM
suicidesam's Avatar
****defected****
i got these http://frickinbrite.com/catalog/prod...roducts_id=214
Old May 26, 2007 | 08:11 PM
perry05G35's Avatar
Since LED project their light to the end of the bulb it will not light up the entire sidemarker assembly like your current halogen bulb does. There are 194 wedge LED bulb with smaller LEDs in it that are angle to dispurse light in all directions they still will not be as BRIGHT as a halogen bulb they will fill up more of the sidemarker but they will not be brighter nor fill the sidemarker assembly as well as a halogen bulb. LED bulbs give you a whiter light over halogen but that has nothing to do with the brightness. What some of us have done though is make your own or buy already made sidemarkers that have circuit boards with multiple LEDS spread through out the sidemarker. It's more expensive but it will not only give you a whiter light output but it will also give you the brightness to match your headlights.
Take a look at this tread for pixs
https://g35driver.com/forums/questionable-posts/144187-official-led-clear-corner-group-buy-thread.html
Old May 26, 2007 | 11:06 PM
Red_G35's Avatar
"White" LED's give off a blueish hue, not at all white. I dont like it..
Old May 27, 2007 | 01:12 AM
perry05G35's Avatar
yeah they do have a HID blueish hue to them but it's not blue like a blue LED.
Old May 30, 2007 | 04:33 PM
jtrudeau's Avatar
I have these bulbs:
<img src ="http://home.comcast.net/~velocityusa/194_HP2_B.jpg">
And here's what they look like, the bluish tint is very marginal with these leds. They are the best that I've used so far: (crappy cell phone pic)
<a href="http://photobucket.com" target="_blank"><img src="http://i13.photobucket.com/albums/a260/jmtrudeau/LED.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
Old Jun 1, 2007 | 10:32 PM
Curt G's Avatar
Not all white LEDs are the same color. I'm using some from SuperBrightLeds.com called "WLED-WHP LED Wedge Base Bulbs". These are the brightest LEDs I've used (brighter than most multi LED bulbs), and they're also very white with almost no blue. Buy 4 so you can put two above your rear plate also.
Old Jun 2, 2007 | 03:28 AM
Red_G35's Avatar
Curt, I recently switch to those bulbs myself. Definitely the closest to a pure white as you can find.
Old Jun 2, 2007 | 04:05 AM
kyazh's Avatar
White LED's usually come in three classifications. "warm white" which is a yellower white and comparable to incandescent bulbs. There is "neutral white" which is more natural and is in between warm and cool. Then there is "cool white" which tends to be on the bluish side. I try to use "neutral white" in all the fabrications I do, this gives it a better look, matches with the factory HID and most other upgrades, and doesn't tick off the cops.
Old Jun 2, 2007 | 05:24 PM
perry05G35's Avatar
I think the LEDs i have in my licence plate area are the cool white where can I get the neutral white for back there Kyazh?
Old Jun 3, 2007 | 02:06 AM
kyazh's Avatar
I buy the individual bare LED's for all the stuff that I work on, I'm sure you're referring to the fabricated bulbs that fit in the stock socket. To tell you the truth, I haven't really looked into those. What types of bulbs go in there anyway? 194? Let me know and I'll do a bit of research! I'm pretty sure someone makes them. I try to keep my license plates as dim as possible
-John
jsimonk
Dec 22, 2023 03:49 PM
khamlin
Aug 2, 2015 09:37 PM
realtalk21
Jul 20, 2015 09:07 AM
wylin
Lights
Jul 18, 2015 06:12 PM
