Headlight recall question ?
Old Jun 18, 2007 | 10:42 AM
V35 Skyline GT's Avatar
6MT Coupe
Originally Posted by by15vc
damn so annoying though, i dont want to have to slip the bumper off. i know you can get through the fender, but not too sure if i want to go through the hassle. but you're right, the mechanics might eff it up...anyone have experience with peninsula infiniti in redwood city?
Search results:
https://g35driver.com/forums/showthr...i+redwood+city
Lots more in results
Old Jul 18, 2007 | 07:26 PM
palung's Avatar
I just replaced my 03 headlights with the 06, one question isn't the bottom light is the fog light? just like 03 lights? I turned all my lights on but both bottom lights won't come on. Is there something I need to do? By the way the headlights came with the orginal bulbs for 06. Thanks.
Old Jul 18, 2007 | 07:32 PM
redlude97's Avatar
Did you check all the connections and make sure the h1 bulbs weren't damaged before installing?
Old Jul 19, 2007 | 11:41 AM
palung's Avatar
one thing I notice when I was checking the bulbs. It's a small bulb just a little bit bigger than the side marker bulb. Is it suppose to be like that?
Old Jul 22, 2007 | 11:57 PM
tomcatm's Avatar
Declined the recall during my last service visit, went in again 2 days ago for my next one, figured declining it once was good enough. But they went ahead and did it without telling me, and now I have lost all my 3 sets of aftermarket bulbs and the clear bra. I am so pissed, but they have agreed to replace the bulbs and the clear bra at their cost
Old Jul 29, 2007 | 01:58 PM
Jason@Riverside's Avatar
The dealers get re-embursed for the Clear Bra.. you have a clear bra when you come to us, we put on light that already have clear bra re-installed... go back to your dealer...
the headlights are no longer street legal... If you get a vehicle inspection, they could fine you...
MOST dealers do not align the headlights after they install the new ones... make sure they are re-aligned and you will be happy... if you have aftermarket bulbs, tell them you want your old bulbs back or installed into the new lights...
Old Dec 19, 2007 | 12:20 PM
2mhighside's Avatar
Alignment
First of all im new to this site so Hello. As for the recall it made no difference i could tell. Alignment is pretty easy and best way to do it is just to remove your inner fender wall. Its a few screws and some of those little pop out fasteners. you will have full access to the adjustments and the back of the light. you will probably need to remove the front tires as well. Once the fender well is removed you can put the tires back on with a few lugs in it and set the car down for adjustment. It will only take 20 mins or so for the whole job.
Cheers
Old Dec 19, 2007 | 01:06 PM
Sportcoupe35's Avatar
can't tell the difference...I had my dealer raise the level of my headlights after install hahahaha....I felt that they pointed too downwards and I wasn't getting enough up ahead lighting.
Its nice to have a set of brand new headlamps though...but...not really worth your time.
Jusseth
Sep 13, 2020 12:25 PM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
as25656800
Aug 9, 2015 07:25 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
