Headlight Question Part2
Old Jun 5, 2007 | 03:02 PM
slimerEPT's Avatar
So last time i asked everyone told me that i was able to pick up a pair of 06+ headlights for my 03 G35 so i can have the projector beam and they wont develope that yellow crust.
So i started looking on ebay and i have seen numerous pairs for sale but without the ballast or bulbs. THey are considerably cheaper of course but i dont know if not having the ballast or bulb from the 06 light will look as good or be able to switch it out with the 03 ballast and bulb that i currently have stock with the 03.
Old Jun 5, 2007 | 03:32 PM
g7x5's Avatar
the ballast are the same, but the bulbs are different yours are now d2r, you'll need d2s
Old Jun 5, 2007 | 03:42 PM
ttrank's Avatar
Grocery getter
You can use the ballast. If you want to use your D2R bulbs you will need to scrape off the ceramic coating on the bulb and mod the base a little.
Old Jun 5, 2007 | 04:18 PM
slimerEPT's Avatar
so i can buy a set of headlights that have the bulbs with them, and just plug and play with the ballast that is mounted in the car?
Old Jun 5, 2007 | 04:23 PM
g7x5's Avatar
yup,
Old Jun 5, 2007 | 05:05 PM
joe603's Avatar
You could just clean your current lights. The yellow crust is usually just dirt that can be removed with a good plastic cleaner.
Old Jun 5, 2007 | 05:08 PM
jtrudeau's Avatar
Here's a link to just about the best priced pair of new bulbs (OEM) that I've found:
Philips 5000K bulbs
http://cgi.ebay.com/ebaymotors/5000K...27451396QQrdZ1
Old Jun 5, 2007 | 05:38 PM
Sooner97's Avatar
Those Philips bulbs are actually the exact same thing as OEM bulbs. They're not really 5000K, more like 4200K. The model number on those "5000K" bulbs are identical to the ones in our stock projectors.
Old Jun 5, 2007 | 05:45 PM
IvoryGT's Avatar
85122+ is NOT 5000K. 85122CM is
Old Jun 5, 2007 | 06:18 PM
g35man04's Avatar
CLUB MODERATOR
most of the headlights ordered off ebay are coming with the wiring and bulbs in all spots...the only part you need in them is...this pictured below which is the ballast. You dont even need the wiring that comes with it...here are the ones i picked up.
part you need:
mine i bought off ebay:
Old Jun 6, 2007 | 03:07 PM
slimerEPT's Avatar
part you need:
so if i buy an 06 set of headlights that have the bulbs I still need to buy another ballast, or can i use the one that comes in my car? what if i pick up a set of headlights that dont come with anything that are alot cheaper and use everything off the 03?
Old Jun 6, 2007 | 03:14 PM
g7x5's Avatar
you do not need to buy another set of ballasts, you can you the ones currently on your car.
Old Jun 6, 2007 | 05:06 PM
Sooner97's Avatar
Not all of the lights in the 03 are compatible with the 06. The HID, turn signal and fog lights are all different.
Old Jun 6, 2007 | 06:32 PM
g35man04's Avatar
CLUB MODERATOR
your wrong man. The ballast is the bottom part of the headlight that i have pictured above that has one wire that runs from it that makes the HID that we have on our cars....the other foglight wiring and turn signal wiring is another who set that is connected to the outside plug on the ballast. The ballast is only the one wire that is connected on the inside plug that runs up inside of the headlight into our low beam that uses the D2r or D2s bulb.
to the poster above you can reuse any ballast from any 03-07 headlight. They are all the same.
for those of you confused here you go....any ballast can be used for D2r and D2s bulbs. The plug on the outside of the ballast is the same from 03-07.
Comparison...
Just ballast, ignitor, and bulb.
foglight, turnsignal, and clearance stip wiring...
Assembled ballast with everything need for light.
Old Jun 6, 2007 | 07:28 PM
redlude97's Avatar
your wrong man.
I think he was referring to just the bulbs, in case the OP purchased a set without any bulbs. 06's can only reuse the clearance bulb from the 03 headlights, and the d2r bulbs, but those require modifications. New lowbeam d2s, foglight H1's, and turn signal 7440 need to be purchased if they are not included
