03 sedan headlight IGNITOR-retrofit? :)
Old Jul 6, 2007 | 10:15 PM
johnsonhuang's Avatar
Brakes 03 sedan headlight IGNITOR-retrofit? :)
So i was about to pick my car up from the shop today after having some bodywork and headlight changed aftera collision and i get a call from my mechanic. He told me that my passenger side headlight was damaged. The ignitor(ballast im guessing) that turns my HID's on is burnt. I already had previous problems with my headlights.
I would turn them on, then i turn them off, then turn them on agian, and it won't go on. I basically can't flick my lights anymore. I would have to wait a while before i would be able to turn them on agian. Im not sure if my after-market hid bulbs caused the problem or not, but he informed me that these were the parts i needed to fix the problem.
The headlight housing comprised of two parts, 26025al520 + 26025ac020
im not sure how these parts work, but i think 26010ac026 is the the combonation of both. (part list on the bottom from Riverside Infiniti)
heres some ways i figured i could go about in fixing my situation.
1.What i want to know is if its possible to just purchase a new ignitor for the headlights.My other headlight that got swapped out is fine, but its on the drivers side so i was wondering if i could take apart the housing (bake it in an oven) and swap it to save some money. Also gives me a chance to paint my housing =)
2.Project retrofit and forget the whole thing! but keep in mind (im not exactly the best mechanic)
3. Just let the shop deal with it and fork over 500-600 bucks for a whole new assembly...
__________________________________________________ _______________
Part Number: 26025al520
Electrical - Chassis electrical - Headlamps - Composite headlamp Composite headlamp, g35, xenon, right 2003 - 2004
Part Number: 26025ac020
Front lamps - Headlamp components - Lens and housing - From 12/02 From 12/02 Right - Xenon type 2003-04 2003 - 2004
Part Number: 26010ac026
Electrical - Chassis electrical - Headlamps - Composite assy Composite assy, g35, xenon, right 2003 - 2004
Old Jul 7, 2007 | 12:56 AM
ILLicit's Avatar
Dont get a whole new assembly. What do you exactly need? The igniter or the ballast? Either way... I have both that I can sell to you. It's from an 03 G35 Sedan. Let me know if you want it.
Old Jul 7, 2007 | 03:02 AM
well, thats what im unsure of. he said igniter, which i believe is where you plug the bulb into. isn't that apart of the whole hid balast?
Old Jul 7, 2007 | 10:16 AM
sfgr415's Avatar
Well... there is the ballast (small grey box), and then there is the cable that connects from the ballast to the wire harness.
Old Jul 7, 2007 | 01:53 PM
GreenGoblin's Avatar
The goblin resurrection
ya no need to get a whole new housing
Old Jul 8, 2007 | 06:40 PM
does anyone know how to remove these two screws from inside the headlight housing.
the two circled screws, im having trouble removing. Its angled at a point where my screwdriver can't get any grip.
essentially, what i want to remove is
so i can get to the control and ignitor.
one of my HID Ignitors burned and i have a extra headlight laying around, but its on the wrong side, so i wanted to swap the ignitor + controller to the other side.
If things go well, i might consider just getting a whole new McCulloch HID Conversion Kit and swapping out both sides to make sure it works.
Old Jul 8, 2007 | 07:19 PM
use a flexible screwdriver?
Old Jul 8, 2007 | 07:28 PM
theres such a thing?
Jusseth
Sep 13, 2020 12:25 PM
itgogitrev
Lights
May 2, 2016 06:53 AM
tiguy99
Mar 1, 2016 11:42 AM
derres
Aug 28, 2015 03:27 PM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
