HID Headlight QUESTION
Old Jul 22, 2007 | 03:05 AM
j 4 lD's Avatar
Question HID Headlight QUESTION
I currently have stock HID's on my 2003 Sedan but i wanted to make them brighter to 6000k. What would I have to do? do i need a new bulb or bulb and ballast or what! Someone please help, thankyou!
Old Jul 22, 2007 | 03:08 AM
RichardxG35's Avatar
just replace the bulbs
superdds's Avatar
you just need to buy d2r bulbs rated at 6000k however they will NOT be brighter. they will be more blue. the higher the kelvin rating, the lower the light output.
Old Jul 22, 2007 | 03:09 AM
redlude97's Avatar
yep,they'll be 25+% dimmer than stock depending on brand
Old Jul 22, 2007 | 03:11 AM
j 4 lD's Avatar
I wanted to definitely make them brighter and have a slight hint of blue-ness. But i don't want to over do it . What would you guys recommend. By the way thanks for the feedback.
Old Jul 22, 2007 | 03:12 AM
j 4 lD's Avatar
I wanted to definitely make them brighter and have a slight hint of blue-ness. But i don't want to over do it . Do i need a new ballast? What would you recommend. By the way thanks for the feedback.
Old Jul 22, 2007 | 03:16 AM
superdds's Avatar
your stock hid's rated at around 4300k is going to be the benchmark in brightness. as soon as you go higher to achieve that bluish tint, you will lose light output. you can't have both. having said that, i wouldn't go higher than 6000k if you want your hid's looking a bit more blue.
Old Jul 22, 2007 | 03:18 AM
j 4 lD's Avatar
so what if i wanted to make them brighter with out caring about the color. I just want more light coming out of them. But if i only wanted to make them a little bit blueish, all i would have to do is replace the bulbs?
Old Jul 22, 2007 | 03:29 AM
superdds's Avatar
as i mentioned earlier, our stocks are rated at around 4300k. daylight at noon is around 5000k. so if you want max light output, you'd want a 5000k bulb however, i doubt you will notice much difference.
Old Jul 22, 2007 | 03:42 AM
redlude97's Avatar
If you want better output, your only option really is to do a projector retrofit. You can get increased output as well as blue/purple flicker
Old Jul 22, 2007 | 03:45 AM
superdds's Avatar
+1
Old Jul 22, 2007 | 05:28 AM
j 4 lD's Avatar
Thanks for the help guys. I think im just gonna get a pair of 6000k bulbs for my HIDs and some brighter fog/high beams. they are the same light right? (fog and high beams)
Old Jul 22, 2007 | 08:57 AM
RJones's Avatar
No, fog and daytime running lights are the same thing.
Old Jul 22, 2007 | 11:36 AM
anhhuy88's Avatar
the philips ultinons are the best as in output and color.
Old Jul 22, 2007 | 12:44 PM
sfgr415's Avatar
^^^ they have a nice color, but not great output.
