Changing rear lense bulbs
Old Aug 11, 2007 | 08:39 PM
Ozz's Avatar
Ozz
Got to replace a bulb in the rear of my 03 Coupe, and want to try for a quick tip before I go out there and break something. I get that way
Anyway I see some plastic clip-rings which appear to be what I need to remove but they just spin and go nowhere. If I pull any harder on the carpet trim, something is going to break, tear, or both. I don't want that.
The bulb I need to access is the basic rear lamp on the side. Thanks
Old Aug 12, 2007 | 01:18 PM
sfgr415's Avatar
if you are talking about the ones that hold the cargo mat, there is a small slit for you to insert a flat head screw driver. You can pop it out just like a normal clip.
Old Aug 12, 2007 | 03:08 PM
Need4SPEED05's Avatar
^^^^Like he said. Just turn that clip until you see the slit. Goodluck.
Old Aug 13, 2007 | 07:37 AM
Ozz's Avatar
Ozz
Makes sense. Thanks guys.
Th611
Oct 27, 2015 03:48 PM
atk08
Jul 30, 2015 03:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
nascarbuff17
Jul 16, 2015 10:23 AM
attarday
Jul 15, 2015 04:03 PM
